Results 1 to 24 of 24
    Aug 2005
    Europe
    I have been using a Samsung SSD 840 PRO for almost five years with no problems. My next purchase will probably be again a Samsung, even though they are more expensive. As far as I know they are the only ones with a warranty of 5 or 10 years. What SSD are you using and you would recommend?
  2. Member stax76's Avatar
    Nov 2009
    On thin ice
    I've never used anything but Samsung, never had a problem with Samsung but had problems with other brands (I don't remember which brand it was).
    Apr 2003
    I have used Samsung (2) and Crucial. My Samsung in my laptop died but Samsung quickly replaced it since they could not repair it.
  4. Member stax76's Avatar
    Nov 2009
    On thin ice
    Now that you write it I think it was Crucial I had major problems with, not buying from this brand again!
    Apr 2003
    Have not had one lick of trouble from the Crucial, and it's 6 years old.
  6. Member stax76's Avatar
    Nov 2009
    On thin ice
    It was a low end drive with ridiculous shitty controller built in.
    - Samsung EVO
    - Crucial MX500
    I won't buy anything else.
  8. Mod Neophyte redwudz's Avatar
    USA
    I have three Samsung EVOs and no problems with any of them. Two in my PCs and one in my laptop.
    But with any SSD, check with the motherboard manufacturer for compatibility.
  9. Member Cornucopia's Avatar
    Use those 2 also. And Kingston upon a time, though not any more - we get better bulk deals w the other 2.
    Aug 2006
    I'd probably buy a Samsung drive if I needed another SSD now. SSD prices have decreased dramatically. Today the 480 GB PNY drive that I bought early last year for $120 (inexpensive at the time) is on sale for $50 at Amazon. It has a 3-year warranty.
    I bought the less expensive PNY SSD because instead of a Samsung SSD because wasn't sure if an SSD was really worth the extra cost. I delayed using the SSD due to a problem with the PC that cropped up at about the same time I bought the SSD. (Replacing the PSU and SATA cables seem to have fixed it.) I just installed the PNY SSD a couple of weeks ago. So far, all is well and I like the faster load time for what is now my HTPC.
    Aug 2005
    Europe
    Samsung Magician reports 5,125 Read and 5,375 Write for Sequential (MB/s) and 207,035 Read and 121,100 Write for Random (IOPS). How good are these benchmark results?
  12. "Keeping it Weird" Austinfilmstock's Avatar
    Apr 2019
    Texas
    Samsungs here too...sounds like a strong verdict for them in most post so far
    Aug 2004
    PA USA
    I'm using Samsung 860 EVO, no issues on all three of my computers, Dell Vostro, Toshiba laptop, Lenovo laptop. I suspect other brands have increased quality over time but, I have no experience with them.
    It's not important the problem be solved, only that the blame for the mistake is assigned correctly
  14. Video Restorer lordsmurf's Avatar
    Nope.
    Watch Linus Tech Tips on Youtube, about SSD drives.
    Aug 2005
    Europe
    What do you think about the above benchmark results?
    Aug 2005
    Europe
    Latest (6.0.0) Samsung Magician reports around 550 Read and 350 Write for Sequential (MB/s) and 87000 Read and 77000 Write for Random (IOPS). These performance benchmark results are different from the previous results above. Does anyone know why? And again, how good are they? I would expect results for Write to be closer to Read.
  17. Member p_l's Avatar
    Montreal, Canada
    My WD Blue 1TB SSD has breathed new life into my old rig and has been flawless all year since I got it. Time will tell.
  18. Member Ennio's Avatar
    May 2005
    Netherlands
    Build my pc in 2012. For C-drive (Windows) I installed an Intel SSD. Still running. Never had a problem with it. My pc is powered on 24/7
    Aug 2005
    Europe
    I am building a second system from extra parts that I have and I am thinking to either use the 840 PRO from my first system (and replace it with a 860 EVO) or buy a cheap SSD for the second system. The 840 PRO is almost five years and has less than 15TB written. What do you think?
  20. SanDisk used to build their own SSDs, they're now part of Western Digital; Crucial SSDs are made by Micron, which also makes drives under its own name. As to which is best -- I work in tech support for a university, seen a lot of Micron SSDs (OEM and other), SanDisk, Samsung (which makes their own SSDs but their hard drives are now made by Seagate), and frankly they've all held up just fine over the past few years we've been supporting them. I'd probably go for a drive with a longer warranty at whatever price point I'm looking at, but for my own home systems (and a lot of work systems) a 256gb drive is around fifty bucks, hard to go too far wrong at that price. Just remember: Backup, backup, backup!
    EDIT: Oh, yeah -- use an SSD for your boot/OS drive, you can keep it small, use a larger SSD/spinner drive for data (I've got a stack of 1TB and larger SATA spinner drives for data), connect via SATA, USB2/3, eSATA, NAS, whatever, even a cheap small SSD can rejuvenate an older computer using a spinner for OS.
  21. Video Restorer lordsmurf's Avatar
    Hi ozymango, long time no see.
    It seems newer SSD are actually getting worse for speeds and reliability.
    I have some 850 4tb SSDs for video/photo.
  22. Originally Posted by lordsmurf View Post
    Hope you're feeling better, my friend!
    Oh man, 4tb SSDs for video, that's the dream -- I don't do hardly any editing/capturing like I used to, I do some short clips here and there but not the old 2+hr 50gb HuffYUV avi files I used to have drives full, back in the day, before all the stuff I'd recorded over the years off TV came out in 1080p restored versions I could get from Amazon for ten bucks ... ah, but good times. But yeah the throughput on a capturing/recording/editing setup using all SSD drives, man that is sweet. Now I do have a big project for this winter (always "this winter" for the past five years or so) where I scan all the snapshot prints my family has taken over the years, into tiff/jpg files for the family history books, it's only a few thousand, how long could it take?
  23. ProductChart provides a really neat way to browse what's out there:
    https://www.productchart.com/ssd_drives/
Name:	2019-10-19 13_03_40-SSD Comparison Chart.png
    Creator of Video Hub App
  24. joollyjohn jollyjohn's Avatar
    Mar 2005
    Sydney Australia
    Nope.
    Any possible link?
