Results 1 to 12 of 12
  1. I'm used to working on animation sources and not live footage. I have a source that looks like they added in TONS of artificial grain over the film. When you look at the background, there is a huge amount of it and it's very distracting and annoying.
    I have tried multiple types of noise/grain removers, and they kind of help but they have not been doing too well at it. The only way I have been able to get rid of those colored specks is with mctemporaldenoise(sigma=5, sharp=false, radius=1, ecrad=1). Anything lesser than sigma of 5 doesn't get it out of the background well enough. It's been smearing things out though, because of the strong noise removal. The others I tried did more detail damage and less background noise removal, but this is still kind of overkill.
    Is there a better alternative to removing this grain or at least making it harder to see without smearing away as much detail, or blurring the overall picture a lot?
    Screenshots
    https://forum.videohelp.com/images/imgfiles/ERWOITN.png
    https://forum.videohelp.com/images/imgfiles/9qcJnxH.png
    https://forum.videohelp.com/images/imgfiles/DonnkpR.png
  2. You can perform heavier filtering on the chroma and lighter filtering on the luma:
    MergeChroma(TemporalDegrain(weak settings), TemporalDegrain(heavy settings)) # or TemporalDegrain2(...)
    You should know to provide a video sample by now.
  3. Gimme a moment to make one
  4. Tried both
    MergeChroma(mctemporaldenoise(sigma=2, sharp=false, radius=1, ecrad=1), mctemporaldenoise(sigma=5, sharp=false, radius=1, ecrad=1))
    MergeChroma(TemporalDegrain(sigma=2), TemporalDegrain(sigma=6))
    and
    Chroma=last.mctemporaldenoise(sigma=5, sharp=false, radius=1, ecrad=1)
    Luma=last.mctemporaldenoise(sigma=2, sharp=false, radius=1, ecrad=1)
    MergeLuma(Luma)
    MergeChroma(Chroma)
    Didn't really have any luck with this working any different or better than before when it comes to the mctemporaldenoise. The temporaldegrain was removing it better, but it was smudging away everything else detail wise way worse.
    Am I not separating chroma and luma filtering properly?
  5. I haven't looked at the dark scene yet but just TemporalDegrain2(degrainTR=3) works pretty well with the bright clip. If you use TemporalDegrain() you'll need to try settings lower than the default, SAD1=200, SAD2=150, sigma=8, or thereabouts.
  6. Funny, I just tried to upload a degrained sample and it's not coming up..
  7. Anyway, just simply use this simple script. I think you'll really like the results.
    SMDegrain(tr=3,thSAD=400, subpixel=3, contrasharp=false,prefilter=2,str=8.0,refinemotion =true, truemotion=true, lsb=true, chroma=true)
  8. Originally Posted by Betelman View Post
    That leaves more noise but it's much better at retaining small "sparkles" in moving areas.
  9. Right, we want to avoid removing details. But it removed a significant amount of grain.
  10. Member steptoe's Avatar
    I have good results with this script that is less aggressive noise removal but seems to be very good at removing background noise
    https://forum.doom9.org/showthread.php?p=618853#post618853
    For more aggressive grain removal I use this script, but you can also use another denoiser to do a more aggressive preclean simply by changing one line and adding it to the script, which I do for heavy grain removal or even scratch removal from very old sources. It also works with B&W sources
    https://forum.doom9.org/showthread.php?p=1694939#post1694939
    Change this line in the script to add your own prefilter
    alt=input.RemoveGrain(2)
    Some examples I use occasionally are
    alt=input.fluxsmoothst(3,3)
    alt=input.msmooth(threshold=5,strength=3,highq=tru e,chroma=false)
