Hello,
new "Subtitle edit" user here.
While moving between the different subtitle lines (using Alt up/down arrow) is there any way to make the waveform panel keep showing the current selected subtitle (the red part)?
Hope I have been clear.
Thank you,
Spiff
Let me try again:
Is there any way to make the waveform panel keep showing the waveform part related to the current selected subtitle? So that if I select another subtitle (using Alt up/down) Subtitle Edit shifts the waveform accordingly? -
If you double click on a subtitle, or use alt up/down, is the new subtitle the "currently selected" ?
And doesn't the video and audio graph update to the new location with the selected subtitle audio graph
appear in red?
I don't really understand your question, but I'm not an expert in this program. You can always email the author,
contact here:
https://www.nikse.dk/SubtitleEdit/Help -
Here it is the solution. I set a shortcut in
Options -> Settings -> Shortcuts - Go to prev/next line and set video pos
Best regards, s.
Subtitle Edit - waveform problem
By AllaRosie in forum SubtitleReplies: 8Last Post: 12th May 2024, 06:21 -
Subtitle Edit - Waveform not complete
By batko in forum SubtitleReplies: 0Last Post: 29th May 2019, 10:51 -
waveform problem in Subtitle Edit 3.4.6
By whitelighter27 in forum SubtitleReplies: 2Last Post: 15th Mar 2019, 07:14 -
This dummy can't sync subs with Subtitle Edit or Subtitle Workshop :-(
By inspector_plodder in forum SubtitleReplies: 6Last Post: 24th Aug 2018, 19:33 -
Pixelated and laggy video on Subtitle Workshop and Subtitle Edit
By Valerc in forum SubtitleReplies: 5Last Post: 15th Jul 2018, 12:37
