hSplit is a small command-line tool that lets you split and join files bit by bit very quickly.
This project is open source on GitHub.
Downloads:
Windows(32)
Windows(64)
Linux
Src
Code:hSplit rev(init) ----------------------------------------------------------------- Syntax hSplit.exe [Param1 [Value1 [Param2 Value2 ... ...]]] "Source.file" ["..."] ----------------------------------------------------------------- Parameter -h > Show this Help -S > Segments: split file into segments (default is split Chunks) an array of comma separated start and end bytes is used values for start and end can be an Integer or a Hex string to use hex values set a first char to "h" -> h0-1000,2abc-4def the end byte is NOT included in the target file if an end value is set to 0, it means end of file(last byte) a byte pair of 0-0 means copy the entire file and will be skipped the start byte must be smaller than the end byte -s > Chunk size: value is an Integer and default means Megabyte (def=20) a first char can be set to define the value type b=Byte; k=Kilobyte g=Gigabyte -c > Chunks count: How many chunks should be written if not set or set to 0 means infinity until the source file ends (def=0) -t > Target folder: if not set or empty the source folder is used -n > Target file name: if not set or empty the source filename is used -P > Progress interval: Control how often the progress is send to the output value is a Byte from 0 to 255 value 0 sends no progress numbers; 1=max 255=min (def=100) -J > Join files: value is a path for a target file only the -P switch can be used additionally ".." > Source file: MUST be the last parameter! Path to source file @".." > Path to a parameter file: MUST be the first parameter! The parameter file should be a simple text file You can use any name and extension for the file name Only source file parameters can be used additionally ----------------------------------------------------------------- Parameter file Each line is used as a parameter If you don't set a source path in the parameter file, the source path(s) is(are) read from the command-line. You can use a root parameter file called "params.txt" Exists this file in the root folder of hSplit, it will be used automatically. If the "params.txt" is empty, it will be ignored. ----------------------------------------------------------------- Command You can send a command while hSplit is running. Command will be executed after pressing the ENTER key "e" > User Exit: stops hSplit ----------------------------------------------------------------- Exit codes hSplit sends at the end an exit code 0 - all OK 1 - no source file 2 - error while loading source file 3 - no target folder (not found or could not created) 4 - chunk size too big (bigger than the source file size) 5 - nothing to split (no data) 6 - nothing to join (no data) 7 - parameter file not found 8 - parameter file is empty (only if used with the cli parameter) 9 - wrong parameters 99 - internal Lazarus error -1 - User Exit ----------------------------------------------------------------- Examples Split chunks: hSplit.exe "Path\to\source.file" split entire source file in 20mb chunks hSplit.exe -s 100 "Path\to\source.file" split entire source file in 100mb chunks hSplit.exe -s g2 -c 10 "Path\to\source.file" split 10 chunks with 2 gigabyte each hSplit.exe -t "trg dir" -c 10 -n "trg name" "Path\to\source.file" split 10 chunks with 20mb each to folder "tar dir" with name "trg name" the file extension is used from the source file Split segments: hSplit.exe -S 0-1000,5000-6000,500-1500 "Path\to\source.file" split three segments with 1000 bytes each hSplit.exe -S h0-1000,5000-6000,500-1500 "Path\to\source.file" split three segments with 4096 bytes each Join files: hSplit.exe -J "Path\to trg.file" -P 0 "Path\source.1" "Path\source.2" join 2 files without progress numbers Parameter file: hSplit.exe @"Path\to MyParam.file" all parameters are read from the parameter file hSplit.exe @"Path\to MyParam.file" "Path\to\source.file" the source parameter from command-line is used (no path in the parameter file) (if you want to join files, you can specify more command-line parameters)
It's good to have more options. But how does your software differ from the numerous other file splitters (many of which are free and open source too)?
You can split multiple segments and you can join files. It is not a new wheel, it's more for me to learn programming a cli tool.
More info you will find in this thread. -
A small update to rev0.01
Downloads
Code:changelog hSplit added & fixed * improved # changed % rev0.01 * small issue for joining if a source file is not present # size type can now be also the last char (1b or 2k or 3g) - only one type is allowed: first or last position
downloadCode:
change hSplit added & fixed * improved # changed % rev0.02 - 01.10.2020 hSplit not working if the root parameter file (params.txt) is not present and no parameter file was set in the commandline
Best free way to split or join .MP4 files?
By Nagashi in forum EditingReplies: 31Last Post: 15th Nov 2023, 23:16 -
Any command line tool for windows to edit MP4 metadata without remuxing?
By dothrakihorde in forum EditingReplies: 7Last Post: 16th Aug 2018, 18:00 -
Command line tool to extract wma from wmv?
By EdenResident in forum Video ConversionReplies: 7Last Post: 10th Aug 2018, 02:42 -
How to multiplex avi files on linux/mac/windows? (command line)
By Selur in forum Newbie / General discussionsReplies: 4Last Post: 27th Jan 2018, 08:30 -
Recommended command line cross-platform download tool, not youtube-dl?
By colorstar in forum Newbie / General discussionsReplies: 0Last Post: 12th Dec 2017, 07:38
