Hi all
I have a GoVideo4000 and aparently it will only play professional vcds.
Does anyone know the what makes them professional? What's the difference between those and ones burnt in a cd-rw?
Results 1 to 15 of 15
Never heard them called professional but I think what it means is original vcds like you buy in malaysia and other asian countries, that's where most original vcds come from.
We were all NEWBIES once and the only stupid question is the one that's not asked? -
The difference is that Professional (manufactured/mass produced) VCD's are pressed and not burned which is what we are doing when we create custom VCDs on CD-R media for the home.
There is alot of fustration going around when buying DVD players that also play VCDs, and one of the topics that come out all the time is "Why doesn't my VCD work on my DVD/VCD player"
What worked for me is that if a DVD/VCD player plays CD-Rs (MP3) CDs then it should play my custom VCDs and I haven't had a problem since.
Hope that help.
Rallytbk -
good job RALLYTBK, I should have just typed it all in but was too lazy and I thoght he would have undertood what original meant.
I'm just pissed that i was told that the dvd player would play vcds, and i assumed that meant all vcd's
i'm a little confused here. is your player a VCD player that will only play commercial VCD's or is it a DVD player..i'm not familiar with the GoVideo4000...who makes it?? and, if its a DVD player that you just got then who told you it will play VCD's and why not just return it??? if you've had it for a while why not just get a new player.. an Apex player can be purchased for about 100 bucks and it plays EVRYTHING............
It's a GoVideo or i think the company might also me called SensoryScience. It's a DVD/VCR combo. I receieved it as a gift last christmas and just got around to popping a VCD in over the weekend. It said on the box that it plays them, so i emailed the company and they said it will only play professional VCD's.
OK HAPPY DUDE,
Calm down I just did something you should have done yourself:
I just LOOKED in the DVD PLAYER SECTION (the link is to your left)
Now I'm not going to tell you what I read under readers reviews
YOU going to have to do some WORK here
When your done READING IT come back here and TELL everyone what
you just READ
Hope this helps VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked? -
OK, don't worry yet. Before you return it try this. My Sampo plays practically everything, but the family 3 year old sony carousel dvd player won't play any of my home made vcd's. However, I tried CDRW's, even the Comp USA brand and they play fine on it. I have burned them with NERO and now I PREFER AUTHORING and BURNING WITH ULEAD dvd Movie Factory. I get better results with sound on that one. Anyway, I used XTASY 5564 for the capture card. The only complaint I have is the audio is sometimes not synching and the sound a little distorted. Oh well.
HAYMES Don't worry he'll be back LOOK UP at my post
Hey vcd4me, I noticed signature at the bottom says "We were all newbies at once". Well why dont you cut some of these people some slack and quit acting like it is a bother to you for someone to ask a question about something that you seem to take for grantite that everyone should know. I noticed you do this in several posts. Either answer the question or let someone else post with a Real answer. Sounds like you are just trying to pad your threads posted number to me.
Boxingjunkie
I'm not an idiot, i read that information before i asked.
I've tried a TDK blue-green dye, a sony 74 min and a TDK cd-rw and none of them would play.
The VCD was burned standard compliant with Nero. -
HAPPYDUDE,... I never said you were an idiot but I have answered at least 12 people this weekend alone who haven't read enough on this site
I have a player and they told me it wouldn't play cdr or vcds but guess what it does.
BOXINGJUNKIE DO ME A FAVOR AND LOOK AT HOW MANY PEOPLE I HAVE HELPED ON THIS SITE. SOME WHO DON'T BOTHER TO READ. HEY I DON'T KNOW IT ALL - NEVER SAID I DID. IF YOU ALSO READ I HAVE SOME GOOD QUESTIONS THAT WENT UNANSWERED, SO I JUST TRY TO HELP THE CONFUSED LIKE I WAS 1 MONTH AGO. I DON'T DO THIS TO BUST CHOPS BUT LOOK AT SOME OF THE POSTS OUT THERE LIKE:
I GET NO AUDIO... OR PROBLEM WITH TMPEGENC...THEN I GO INTO IT AND HELP THEM BUT ALL THEYHAD TO DO WAS READ.
AND WHAT IS PAD MY THREAD COUNT (whatever that means)..
HAPPYDUDE I"m SORRY if I offended you I didn't mean it that wayJust a suggestion try to pm some of those guys who said they got it to work.We were all NEWBIES once and the only stupid question is the one that's not asked? -
BOXINGJUNKIE, don't bust my chops either you haven't made a post since dec 23 , and just because the two post you made today happen to be in the same thread dosen't mean i say funny or wise things all the time. Oh yeah I noticed your another person with an avi question . DID I bust your chops earlier NO
portrain professional (the ad)
By Spiny Norman in forum Off topicReplies: 1Last Post: 27th Jul 2011, 14:19 -
Need Help about Professional Subtitling
By kei_siuip in forum SubtitleReplies: 1Last Post: 14th Mar 2011, 03:04 -
Buying a professional or semi-professional camcorder
By besimky in forum Newbie / General discussionsReplies: 8Last Post: 2nd Mar 2010, 16:21 -
Maven3D Professional 1.32
By Benjy in forum AudioReplies: 1Last Post: 31st Jan 2010, 01:35 -
I want to become a MPEG professional...
By Mohnish72 in forum ProgrammingReplies: 14Last Post: 24th Jan 2010, 09:49
