  1. Hello! i need your help!
    I would like to check (or downloads) a list of streams.
    for example on a website:
    rtmp://videosite.com/ there are streams called stream1, stream2...etc...to stream100
    i want to check which stream is available (may be in a log file) and optional download them...
    i saw there's the command -Y for a playlist but i dont know how to use it (and if it's what i'm searching for)
    thank you!
  2. Hi!
    So no one knows? May be wuth another method than rtmpdump?
    i found a website which can check if a rtmp stream is available, but i wanna check like 1000 streams....
    thanks again
