Hi. I indexed the VOBs within a VIDEO_TS file with MeGUI (DGDecode) and left the DAR at 6480:4739. Due to a little bit of black line either side, I added 'crop(2, 0, -2, 0)'. The resulting file was very wide and very short with mediainfo saying 21.258 (as opposed to 1.333). Removing the crop instruction gave me a normal output.
Any idea what happened here? Thank you
Results 1 to 13 of 13
# Set DAR in encoder to 6480 : 4739. The following line is for automatic signalling global MeGUI_darx = 6480 global MeGUI_dary = 4739 LoadPlugin("E:\MeGUI\tools\avisynth_plugin\NicAudio.dll") LoadPlugin("E:\MeGUI\tools\dgindex\DGDecode.dll") a=DGDecode_mpeg2source("E:\VIDEO_TS\VTS_01_1.d2v") b=NicAC3Source("E:\VIDEO_TS\VTS_01_1 T81 2_0ch 192Kbps DELAY 0ms.ac3") audiodub(a,b) crop(2, 0, -2, 0) #Spline36Resize(712,480) # Spline36 (Neutral) ### THIS RESIZE WAS AUTO DONE BY MEGUI BUT I DIDN'T USE IT. ORIG SIZE IS 720x480 a=loop(70,3328,3328).trim(3328,3328+69).amplify(0).fadein0(30).QTGMC(FPSDivisor=2)++trim(3328,9848).amplify(2).fin(60).fout(80).QTGMC(FPSDivisor=2) a++loop(370,9848,9848).trim(9848,9848+369).amplify(0).fadeout0(30).QTGMC(FPSDivisor=2) -
I take it you've identified a scripting error that I've not seen but aren't prepared to tell me. Why would you waste your own time creating a post, then?
Wtf, just spit it out. As I don't see anything that would cause a AR of 1:21.258
@OP, I'm not really sure what is going on besides the mediaplay you are using is interpreting the DAR wrong. Maybe try muxing it through mkvmerge and select the DAR you want before muxing a new .MKV. -
Thanks for that, KarMa. Cropping 2 from either side gave me that squashed down result as I mentioned above. As an experiment, I tried cropping different values but odd things still happened. I've just left it uncropped - no big deal as the black bits are so small anyway. If there's one thing I've learned since I began video editing it's that there's often all sorts of weirdness involved...
Log as requested. The source is VOB (720x480) and my script was a simple one, something I've done many times before:
It'd be interesting to see if the log reveals why I get a squashed video.. Thanks for looking.Code:# Set DAR in encoder to 6480 : 4739. The following line is for automatic signalling global MeGUI_darx = 6480 global MeGUI_dary = 4739 LoadPlugin("E:\Free\MeGUI\tools\avisynth_plugin\NicAudio.dll") LoadPlugin("E:\Free\MeGUI\tools\dgindex\DGDecode.dll") a=DGDecode_mpeg2source("E:\VTS_01_5.d2v") b=NicAC3Source("E:\VTS_01_5 T81 2_0ch 192Kbps DELAY -24ms.ac3") audiodub(a,b) crop(2, 0, -2, 0) #Spline36Resize(656,440) # Spline36 (Neutral)## COMMAND PURPOSELY DEACTIVATED BY ME trim(1000,1300) -
remux it and set it to 16:9 or whatever the source is
sar get set --sar 64205:70041
Because of this?
---[NoImage] global MeGUI_darx = 6480
---[NoImage] global MeGUI_dary = 4739
----[Information] AspectRatio: 21.259
Aspect ratio and crop dilemma
By magiblot in forum RestorationReplies: 7Last Post: 23rd Sep 2017, 20:08 -
How to change aspect ratio and how to crop a video without reencoding?
By DigitalJockey in forum Newbie / General discussionsReplies: 3Last Post: 7th Jan 2017, 09:32 -
avisynth and pixel aspect ratio
By silicontrip in forum Newbie / General discussionsReplies: 6Last Post: 29th Sep 2016, 03:10 -
Keep aspect ratio in AviSynth?
By Downgraded286 in forum Video ConversionReplies: 61Last Post: 23rd Jul 2016, 17:15 -
How do I crop an entire video and render w/ custom aspect ratio Sony Vegas
By DiGladio in forum EditingReplies: 20Last Post: 26th Nov 2014, 10:05
