Hi all
I spent a bit of time about 6 months ago looking at this but I couldn't get a satisfactory result (see code snippet below).
Every time I've seen this video, on the various free websites, it exhibits the same problem, I'm assuming something
went wrong when it was originally ripped from a DVD and the same bad copy has been floating around for years.
It's 20 fps, but you can clearly see the jumps where the missing frames should be bringing it up to 25 fps.
https://www.youtube.com/watch?v=XBQbPvcqtDU
Here's a clip from the beginning and my code attempt (which worked in a few situations but left these ugly smears in others)
Thanks for lookingCode:#import("C:\Users\davex\Desktop\framerateconverter.avs") #loadplugin("D:\Program Files\AviSynth 2.5\plugins\dctfilter") #loadplugin("F:\Program Files\AviSynth 2.6\plugins\deblock.dll") #loadplugin("C:\Program Files (x86)\AviSynth\plugins\FrameRateConverter.dll") loadplugin("F:\Documents and Settings\Dave Xnet\Desktop\ApplyEvery\ApplyEvery.dll") #import("F:\Program Files\AviSynth 2.6\plugins\Deblock_QED_MT2MOd.avs") #import("F:\Documents and Settings\Dave Xnet\Desktop\jm.avs") orig=dss2("F:\Documents and Settings\Dave Xnet\Desktop\E12 Child's Play.mkv") #framerateconverter(Preset="normal", Newnum=25, framedouble=false,Blksize=8) #FrameRateConverter(25) #NewNum=25,NewDen=1) #convertfps(25) #hangefps(25) #jm_fps(25,dct=3,blksize=32) #deblock_qed() #jm_fps(25,dct=2) #,blksize=32) #sharpen(0.12) #assumefps(23.976) #trim(0,2000) #Orig = WhateverSource() # Make a black clip, the same characteristics as your source BlankClip(Orig) Black=last # Insert black frame in those missing frames (just temporary placeholder, will replace later) Orig InterleaveEvery(Black, 5,2) BlackInserted=last # Generates Missing Frames by interpolation BlackInserted sup = MSuper() #bv = MAnalyse(sup, isb=true, delta=2) #fv = MAnalyse(sup, isb=false, delta=2) bv = MAnalyse(sup, isb=true, delta=2) # ,search=5) #,chroma=false) fv = MAnalyse(sup, isb=false, delta=2) #,search=5) #,chroma=false) interpolated = MFlowInter(sup, bv, fv, time=50.0, ml=100).DuplicateFrame(0) replace = interpolated.SelectEvery(5,2) # Delete Black Frames DeleteEvery(5,2) # Replace Deleted Frames With Interpolated Frames InterleaveEvery(replace, 5,2) #version() #return last
It looks pretty much like I would expect. None of the motion interpolation filters deal well with complex motions, rotations (2d or 3d) or with objects moving over complex backgrounds. You can try using InterFrame() which lets you tune for smoother motion with more distortions, or less smooth motion (frame blending) with less distortion.
Getting rid of frame interpolation in VHS captures
By EvilEivind in forum Capturing and VCRReplies: 10Last Post: 1st Jul 2019, 11:49 -
Best software for motion interpolation?
By SpoCk0nd0pe in forum EditingReplies: 6Last Post: 24th Feb 2017, 11:37 -
24p to 60fps using frame interpolation on OSX
By bmick23 in forum Video ConversionReplies: 1Last Post: 17th Mar 2016, 16:06 -
Area interpolation filter?
By ndjamena in forum RestorationReplies: 9Last Post: 17th Jan 2016, 01:48 -
Delete
By killerteengohan in forum Newbie / General discussionsReplies: 0Last Post: 30th Aug 2014, 23:15
