So ive been googling for weeks on and off for an easy solution to this.
I want to convert my 23.976 movies to 25.000 without losing quality, so i dont wanna reencode them..
Just speed them up, video and audio, im probably stupid but can it be so hard 2019 to just speedup a video/audio file? :/
MKVToolnix might be able to do it from what ive read? i just wanna remux it i guess...
Results 1 to 11 of 11
In MkvToolNix-GUI select the video track, set the "Default duration/FPS" to 25, and enable "Fix bitstream timing info". Then "Start multiplexing". You may have to adjust/encode audio separately.
box4m, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz -
There's another thing to try: Hi-light the video set "default duration / FPS" to 25.
Hi-light the audio and set "stretch by" to 23.976/25 -
I use Audacity. With the ffmpeg source plugin it can read audio directly from A/V files (or you can use MkvExtractGUI to extract your audio and load it into Audacity without the ffmpeg plugin). You can then use the Change Speed/Tempo filters to adjust the length. Save with whatever audio codec you want. Remux with the video. My preference is usually AVC+AC3 in MKV.
I use daws a lot - like StudioOne - and have really capable stretching abilities - with video preview too.
You don't get video thumbnails in StudioOne - just the preview video.
But daws that do video should work - Cubase, Reaper, Sonar etc.
So operation in daw would be import original video and extract audio - and save away.
Then import fixed video - and extract audio - and discard audio.
Import original audio from disc.
Then set stretch audio so that clip end in the same spot as video.
You basically just drag clip to end to the spot where video ended.
So you carefully identify any spot in video you want as - set a marker on marker track, and timebase to frames.
Latest StudioOne Pro 4.5 do writing of video with new audio in it if you want.
Or just render the stretched audio and import into your video editor with the fixed video(with discarded audio).
Something like this - should work.
But have not done stuff with lipsync which is critical, I guess.
But I would certainly try this approach.
How to downscale MP4 without losing quality?
By Master Tape in forum Video ConversionReplies: 9Last Post: 8th Jun 2018, 15:32 -
Convert .mov file to .mp4 (without losing quality) for playback on a 42" TV
By cjborntorun in forum Video ConversionReplies: 3Last Post: 9th Feb 2017, 06:45 -
Rip VCD without losing any quality
By PannenkoekenNL in forum Newbie / General discussionsReplies: 8Last Post: 5th Sep 2016, 14:01 -
Convert DVD main feature to video file without transcoding/losing quality?
By kingmustard123 in forum DVD RippingReplies: 1Last Post: 18th Jul 2016, 21:19 -
Resizing videos to the same res without losing quality.
By quetzalin in forum Newbie / General discussionsReplies: 20Last Post: 5th Sep 2015, 07:59
