Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. What are some of the best applications to turn a 720P MP4 video into an animation or cartoon style video? I saw a website cartoonizevideo that advertises software for Windows, but I was not clear on whether their software is reputable. I wanted to check the best commercial options here first.
  2. Another effect I want to master is taking a video scene where two people are conversing and making the entire background behind them a colored pattern, like a kaleidoscope. I guess this is normally done with a green screen. Is there any software that would be able to pick out the shapes of the humans talking and replace the scene behind them?
  3. not without a green screen
  4. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    You could try a freeware VirtualDub Cartoonizer filter: http://compression.ru/video/cartoonizer/gallery_en.html
    Many other video filters for VD at: http://www.infognition.com/VirtualDubFilters/effects.html
  5. Originally Posted by pone44 View Post
    Depends on the background. If it's static (other than the speakers in the foreground) you can use a difference map.
