Hi folks,
I'm thinking about setting up a Plex server and beginning the massive undertaking of putting my very large Blu Ray collection on it, so I can stream my movies across my devices on the go. I'm fairly familiar with the software that's out there for this, but I'm wondering what the best method/program is for ripping the discs and getting them into a format that can be streamed via Plex, in a relatively lossless way. It's very important to me that it is as lossless as possible. I can buy what ever disk size is required, unless there's a more efficient way to do it without losing much noticeable quality.
I'm pretty sure something like AnyDVD would work, but then I'd have an ISO of the disk. I think I need an MKV, but I'm not sure how "streamable" that is, if at all.
How would you do it?
Thanks.
Results 1 to 12 of 12
Thanks. I’ve used that in the past, but I have concerns about how “streamable” an MKV is. I know it’s only a container, but I’d think a .mp4 would work more smoothly streaming from something like an NVIDIA Shield to a phone or tablet. On the other hand, .mp4, from my understanding, will not have the same quality as an MKV rip. I’m doing a mountain of these, so I need to make sure I get it right.
Thanks. -
MakeMKV will do what you want (with no loss in quality) with the following limitations:
- You'll lose your menus, which requires an .iso (Someone correct me if there's a way to play the menu directly from a the Blu-Ray file folders.)
- The main movie will be one file (the largest) and extras will each be a separate file.
- It may be months before ripping discs with new release copy protection schemes is possible (see below)
- Since MakeMKV is free (while still in Beta, which it has been for years), the current version expires after a few months and you have to download and install the latest version.
That article is for the Smart TV app.
I haven't used Plex in years, but here's some info from Plex:
Setup is for Nvidia Shield here:
https://support.plex.tv/articles/221099988-setting-up-and-managing-plex-media-server-o...nvidia-shield/
And supported media is here:
https://support.plex.tv/articles/200288286-what-is-plex/
"What Media and Devices Work?
Plex supports these media file types
Plex Media Server supports all common media files:
Movies, TV Shows, and Home Video: MP4, MKV, AVI, MOV, DIVX, and more
Music: MP3, M4A, FLAC, WMA, and more
Photos: JPG, PNG, RAW, TBN, and more"
As for .mkv to .mp4, MakeMKV only outputs in .mkv. Others will be able to give suggestions on programs to remux an .mkv to .mp4 -
Note that it's the receiving app/hardware that triggers Plex to transcode if necessary. The link october262 gave shows parameters that are likely to allow Plex to direct stream (no transcoding) to typical smart TV media players (typically the weakest media players). Note that this DOES require reencoding (and quality loss) if your Blu-Ray is MPEG-2 or VC-1.
Container: MP4
Resolution: 1920×1080 or smaller
Video Encoding: H.264 (level 4.0 or lower)
Video Framerate: 30fps
Video Bit Depth: 8
Audio Encoding: AAC
Anyone able to DL videos from a shared Plex ?
By paintedblack in forum Video Streaming DownloadingReplies: 0Last Post: 17th Oct 2018, 21:48 -
need to convert a few mkvs for plex
By towncarblue in forum Video ConversionReplies: 3Last Post: 10th Apr 2016, 09:59 -
Add Plex Channels to Roku???
By raybo in forum Video Streaming DownloadingReplies: 5Last Post: 4th Feb 2015, 14:47 -
Roku quit streaming Plex
By skipper49 in forum Newbie / General discussionsReplies: 2Last Post: 4th Dec 2014, 14:50 -
Roku 3 and Plex Media Server
By doced in forum Video Streaming DownloadingReplies: 6Last Post: 6th Aug 2014, 15:48
