Hi,
Could anyone give me a sample of Dolby-E TS sample or lead to an available sample?
TIA
Thanks Pandy. I will look.
From the incoming SMPTE-337 feed, I generated TS for passthrough. I tried using ffmpeg to convert my TS file with single stream audio (Dolby E) to wav so that I can play to verify whether TS formating is right. That's where I'm getting issues. ffmpeg identifies my file as smpte (as I store Pa/Pb/Pc/Pd before Dolby E Sync word), but not going beyond that.
Probing s337m score:51 size:68508
[mpegts @ 0000028ae07baa40] Probe with size=68508, packets=9 detected s337m with score=51
[mpegts @ 0000028ae07baa40] probed stream 0 failed
[mpegts @ 0000028ae07baa40] parser not found for codec none, packets or times may be invalid.
The sample I got from ffmpeg forum is SMPTE-337 itself but TS packetized. When I convert that to TS using ffmpeg is decodes in pcm which is not useful for my purpose. I tried forcing decode with dolby-e but that didn't work.
Looks like the link you send could give me more info. will investigate.. Thanks.
Suggestions for this sample
By gamjerr in forum Video ConversionReplies: 1Last Post: 20th May 2017, 22:06 -
Can you clean up this sample better than I did?
By Srivas in forum AudioReplies: 2Last Post: 7th Apr 2017, 17:12 -
vcr sample images collection
By vhelp in forum TestReplies: 0Last Post: 6th Oct 2016, 07:57 -
Dolby Atmos or Dolby True HD?
By flashandpan007 in forum Software PlayingReplies: 7Last Post: 8th Dec 2015, 06:21 -
How to record audio like this sample?
By caisys in forum AudioReplies: 8Last Post: 14th Jun 2015, 15:12
