Hi all, looking for some collective wisdom. I have an OK OPD 250 player - and I want to unlock it for all regions' DVDs (purchased in Switzerland, I mostly want to be able to show North American and European discs). Videohelp has a code for the OPD220 -using this advice and the setup button instead of info, I can enter the code, and the TV screen turns black. It does not give me any options to enter numbers or change setup.
Is there another code I should use? Any other suggestions? TV is a Panasonic Viera, but I don't think that matters.
thanks all!
	Hey guys,
 I only registered to help you, as I had the same problem and literally just spent hours to figure it out.
 So heres how its done:
 1. Press SETUP
 2. Go to "Preferences" (not the general setup page but the preference page)
 3. Enter 1, 3, 7, 9
 4. Change region using UP/DOWN
 5. Press ENTER
 You can set the region to 0 and you won't need to change it ever again.
 I hope this helps.
  Canīt change region code anymore - Samsung BD-J5100By shuiten in forum DVD & Blu-ray PlayersReplies: 3Last Post: 13th May 2019, 12:11
  LG BP 250 region free code problems ... please help! Many thanks .By LD2 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 20th Mar 2019, 06:51
  Change (not remove) Region code in ISOBy ckeays in forum DVD RippingReplies: 13Last Post: 10th May 2016, 08:23
  Is there software to burn a Blu-Ray & change/remove Region Code?By andy jackson in forum Newbie / General discussionsReplies: 11Last Post: 27th Dec 2015, 10:08
  Need help to change region code for AWA W991 playerBy annieh in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jul 2015, 06:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
