  1. Member koberulz's Avatar
    Oct 2006
    Australia
    Recently came across the YV12<->YUY2 conversion issue described here: http://avisynth.nl/index.php/Known_Issues
    But trying the suggested replacement throws a "no function named YUY2toYV12i" error.
    The cause of which is pretty obvious if you look at the script: the support functions only run in the opposite direction. What's supposed to be in the other two?
  2. It does not really exhibit the accumulation issue going the other way , and you will only see the effect after multiple conversions
    The chroma shift problem only occurs going the other way (interlaced YV12->YUY2).
    https://forum.doom9.org/showthread.php?p=1487450#post1487450
    The other support functions are in the original post
    https://forum.doom9.org/showthread.php?p=1471623#post1471623
    https://forum.doom9.org/showthread.php?p=1471989#post1471989
