Hello. I have three video clips and a 10-second title clip (created in V-dub - no audio) that I wish to append as one.
Now, the first video clip has sound. But the second clip has no sound, while the third one does.
The trouble is that when I use Avidemux to append them, they ALL come out with no sound. How can I fix this?
Results 1 to 30 of 30
You can only append clips that match
If one clip does not have audio, you need to add blank (silent) audio with the same specs as the other clips (same format, same codec, same sampling rate, same bit depth). -
You can create a blank audio clip in a sound editor (e.g. Audacity) - I strongly recommend you exactly match the length with the length of the video portion, and match the specs (samplerate, bitdepth, codec, bitrate, etc) with the clips you're appending to. Then multiplex the sound clip with the video clip, prior to appending.
You could also do it programmatically in AVISynth, but then, you'd probably be doing the appending in it as well.
Scott -
Why would you reencode (required if using AviSynth) when you only want to append?
Just redo your title clip with the same kind of audio as the others, but silent. Or create and then mux a silent audio clip, perhaps doing it as explained by Cornucopia. And the first and third videos do have the same attributes for both audio and video, don't they? -
I figured out an easier way to do this, and my task is complete: I originally used Killaudio on my second clip to remove the sound. However, this completely eliminates the audio and thus, makes it incompatible with clip 1 and clip 3 (which do have sound). As a result, Virtualdub or Avidemux would not allow me to append them.
To solve the problem, I did a little research on some old threads. I learned that I can simply replace Killaudio with Amplify(0). This allows the clip to still have a sound property, but no actual sound. I did this, and I appended my 3 files and that's the end of that. I would pull what's left of my hair out if I had do to it Cornucopia's way.
By the way, I appreciate the help here but this is the answer I was looking for. You guys just kept telling me to "create a blank clip", but did not explain HOW to do it. At the same token, I probably should have been more clear. Yet, maybe you guys take your own knowledge on these things for granted and perhaps feel that everyone else knows what you know. But I for one am still learning this stuff.
Please don't get me wrong, I like this website and people here can be helpful. But sometimes, the advice given here feels like I'm being asked to use a positron collider just to unlock a cabinet door. -
Nonsense. Do you forget about your posts right after making them? This thread showed how to create title clips:
https://forum.videohelp.com/threads/393326-Adding-solid-black-frames-with-avisynth#post2552271
Earlier in the thread scripts are shown explaining how to create a BlankClip with audio. In addition, the BlankClip page at the AviSynth site explains everything in detail with examples for its use. -
Didn't think that needed to be explicitly spelled out.
Or I could just add Amplify(0) to the clip I wish to silence and call it a day.
And by the way, I take your arrogance and use it as toilet paper.
Believe it or not, not everyone is going to bow down and sing praises to you (or Manono for that matter) for every piece of advice you give here.
Jerkoff. -
That app is certainly more straightforward to use than AVISynth
Sorry about the "jerkoff" comment, but seriously----there are enough arrogant people who post on this website. Once upon a time, you too needed something "spelled out" for you. Let's not forget the name of this website is videoHELP.com, not videoBELITTLE.com
No one is expecting you to "bow down and sing praises". But I don't think it's too much to ask for you to show a modicum of common sense and for you to pay attention to the advice you've been given. You can try all you want to point the finger elsewhere for your own shortcomings, but you're fooling no one.`
Audacity is a basic tool here, for those of us that rely on such freeware as Audacity, AviSynth, and Virtual Dub to help in our hobby. I don't think it was out of line for Cornucopia to expect you to have at least a passing familiarity with it. Your gratuitous insults after he explained how to do it were out of line. By the way, I don't believe that Amplify use you discovered is documented, and I know I've never heard of it being used that way. So, good going on that. -
And while I'm at it---shut up. Cornucopia and I are kissing and making up, and you're ruining a perfectly good and sentimental moment with your bullshit.Last edited by Betelman; 4th Jun 2019 at 20:29.
Geez, do you have a massive inferiority complex or something? By 'documented' I meant in the AviSynth documentation. I already knew you had dug it up somewhere in an old post here, so why wouldn't I believe you? As for learning something new, yes and no. I'll stick with the more traditional ways of adding audio to video, ones such as the one Cornucopia mentioned using Audacity, or the way I mentioned in the thread to which I linked earlier:
A=Trim(Last,0,1000)###1000=last frame before black frame insertion
B=BlankClip(Last,Length=10)###Insert 10 black frames with same characteristics (including silent audio) as rest of video
C=Trim(Last,1001,0)### resume video after insertion of black frames
A++B++C###AlignedSplice
Feel free to have the last word. -
I knew about the Amplify() trick, but, depending upon the length, it can take longer to execute than BlankClip, etc.
To each his/her own.
Scott -
Yes, of course, but he had originally said his video had no audio and he was implying it would create one in the process:
The title of this thread is, "appending video clips with sound and clips without sound".
Only later do we come to find out the original video contained audio and he only needed to silence it, quite a different thing. But yes, I missed that he was using Amplify(0) on a clip that already had audio. Had he mentioned that earlier no one would have had to waste time explaining how to create silent audio using one method or another. All he had to do from the beginning was to ask how to silence audio and this thread would have been over after a couple of replies. Instead... -
What's that? Jagabo is now going to express his follow-up thoughts on the matter? Oh goody I can't wait to read it! Go on honeycakes, go on and show us your jerk pecs! *puts my arm around Cornucopia's shoulder and continues to mumch on popcorn*
Go on honeycakes, we're waiting. Post your ever-so-brilliant observations on your own ideas. Yoohoo! Oh geez Cornucopia manono's head is up his ass again. Tsk tsk...what's that? .....oh it's usually up there?? Ohhhh!
It's because of people like you who go around these threads kissing their asses that they probably think they can get away with being so arrogant.
Different audio format after appending video clips using MKVToolNix
By Modify_inc in forum Newbie / General discussionsReplies: 13Last Post: 3rd Jan 2017, 20:47 -
Using video clips from phones
By wendfd in forum Newbie / General discussionsReplies: 5Last Post: 4th Jan 2016, 03:01 -
Pulling out video sections / clips
By pellouch in forum EditingReplies: 6Last Post: 18th Oct 2015, 13:31 -
Alternative to download sound-only video than recording from sound card?
By yetanotherlogin in forum Video Streaming DownloadingReplies: 2Last Post: 23rd Dec 2014, 13:19 -
Not Finalized Video Clips
By White_Tiger in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 12th Nov 2014, 10:54
