I really like Asian Kung Fu movies and want to re-encode them and hard code/burn in the subs. What is the best method to do this leaving original file size and quality as close to the original file as possible? I've had some luck with AVC and Handbrake, but find the output size/quality hard to predict. Any suggestions?
Results 1 to 15 of 15
Use Handbrake/Vidcoder and if you really want to set a specific size use 2-pass encode
Use bitrate based encoding when you want a specific file size. With bitrate based encoding 2 pass encoding gives better quality than single pass encoding.
That's the problem with bitrate based encoding. There's no way to know the optimal bitrate.
With bitrate based encoding you pick the file size but you don't know what the quality will be. With CRF based encoding you pick the quality but you don't know what the file size will be. -
You can make it faster, like:
https://trac.ffmpeg.org/wiki/Encode/H.264#a2.ChooseapresetandtuneCode:ffmpeg -i original.mp4 -vf subtitles=subfile.srt -preset veryfast output.mp4 ffmpeg -i original.mp4 -vf "ass=subfile.ssa" -preset veryfast output.mp4
HandBrake is based on ffmpeg. Getting the same speed/file size from both is only a matter of choosing the same settings.
How to remove hard coded subtitles ? HELP PLEASE
By TIMETHIEF in forum SubtitleReplies: 29Last Post: 17th Nov 2026, 20:57 -
Problem with Hard Burning Subtitles with Handbrake
By kasfig in forum SubtitleReplies: 4Last Post: 5th Oct 2020, 22:16 -
Batch Run Hard code subtitles to video files
By kamalakar108 in forum MacReplies: 64Last Post: 19th Jan 2018, 10:34 -
Hiding hard-coded subtitles
By MikeBintouch in forum SubtitleReplies: 16Last Post: 15th Mar 2016, 05:00 -
hard coding subtitles with ffmegX on mac
By xinic in forum ffmpegX general discussionReplies: 2Last Post: 9th Aug 2014, 07:02
