It's pretty much the last thing i need to complete my capture workflow, and want a good signal with no crackles or interference when capturing my video tapes.
How much you want to spend?
Try these guys
https://www.bluejeanscable.com/store/audio/index.htm -
I'd also recommend bluejeanscable products. But any good quality audio cable should also work OK. I don't usually recommend Monster brand cables.
In the past I have used Hosas. Decent connectors, flexible cable, never had a problem. And not very expensive.
Monoprice is reputable too, Some expensive cables are so just for the cool look. Rule of thumb good shielded cables is your goal not the looks and keep your cables as short as possible. I personally put the capture device right on top of the VCR and I use 1 foot S-Video and RCA audio cables that didn't cost me more than $20 combined.
I have had mixed results with Monoprice. Bought a bunch of s-video cables from them with out-of-spec connectors. Almost ruined my jacks.
I've had cables from sources other than Monoprice and they were tight as well, In my personal experience the ones that come with VCR's back in the day are the ones that fit perfectly, When they reinvented the wheel and made new molds for them they screwed up the specs. Anyway wherever you buy them from just make sure they have a good return policy.
Thanks guys, i just went for the blue jeans cable. 1 meter long should be enough. Already have S-Video cables from Pearstone, so i'm all set,
Recommendations for basic audio recorder and mic required
By ed wood in forum AudioReplies: 4Last Post: 10th Feb 2017, 04:34 -
Recommendations for 5.1 audio capture device.
By Wam7 in forum Capturing and VCRReplies: 4Last Post: 23rd Nov 2016, 15:10 -
Audio Cable does anyone know the maker?
By stolowim in forum Newbie / General discussionsReplies: 0Last Post: 5th Jul 2016, 11:33 -
Recommendations on good free screen recorder
By technicality1 in forum Capturing and VCRReplies: 8Last Post: 14th Mar 2016, 03:55 -
No audio with HDMI cable
By jyeh74 in forum ComputerReplies: 10Last Post: 12th Jan 2015, 23:49
