Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
  1. The short video below is an example. It will be running fine then all the color drops out, then color comes back, then drops back out. This seems to have sporadically. I have hooked the VCR straight into a TV and it works just fine, no discoloration.
    https://youtu.be/fo7465gf4wc
    I have a very basic, cheap setup. The VCR is running into an inexpensive USB capture device I picked up on Amazon. It has been working fine until recently. I assume it to be the culprit but I don't have a way to know for sure. I am capturing using OBS but have tested other software and the problem persists. I am a total newbie in this space and unsure what to try. I originally thought it was the VCR but not I think otherwise. I know a lot of people talk about a time base corrector as helping lots of issues. Not sure if this is something it would help or not. I hesitate to go down that path. I'm just doing this as a project for my parents and I hate to have a $150 piece of equipment hooked into a $20 capture card. I have accumulated a pile of VCRs from friends and family now and I keep running into this problem. Would a better capture card be the answer? Or would the TBC be the answer? Or something else. I am at a total loss. Any help is appreciated. Thank you!
  2. Member dellsam34's Avatar
    Jan 2016
    Paris Ca, 92345 Mexico
    You just answered your own question.
    Yep, that's exactly the issue. Cheap crappy equipment = low quality.
    Better is possible.
    Better VCR required, better capture card required.
  4. Member Cornucopia's Avatar
    Could also be AGC circuits are being screwed with by presence of (faux?) copy protection signal.
    Some devices crap out altogether but others will still record but fluctuate the brightness, color saturation and/or sync.
    If this is the case, a TBC can help.
  5. Member darkknight145's Avatar
    Feb 2007
    Australia
    looks like it's losing colour lock, try and get a TBC (timebase corrector) it should solve your problem.
    The reason it looks okay on your TV is that Tv's use ACC (automatic colour control) which monitors the incoming colour signal (more precisely burst signal) and adjusts the levels accordingly, so if the burst is low (which this appears to be) it will boost the gain allowing correct colour level and also the chroma circuits to lock on the signal.
