I am trying to convert an mpg I already have and when I load it in tmpg it says that it cannot open or is invalid. I don't want to convert to avi and then back to mpg (which does work) because this is a dvd rip (not my rip) and I want to retain high quality. Any clues on how to get this to work?
Results 1 to 12 of 12
Assuming that your mpg file is MPEG-2 format, you might find your problem will be solved by installing the 'TMPGEnc MPEG2 Plugin', which you can find from the Tools section of this site, under 'Video Encoders'. Follow the instructions to install it.
there are no instructions, just a txt file in japanese that I can't read. The exe file isnt an install file either. How can this work?
I put the files in the directory and now it just freezes up the program, doesnt even give me a warning
Sorry, I thought there were some instructions with it .. I definitely read some instructions somewhere. Try searching the forum.
As far as I remember, you copy the m2v.vfp file into the same directory as the TMPGenc.exe file. You then run TMPGEnc and go into the Option menu/Environmental setting...
Click on the VFAPI Plug-in tab and you should see the MPEG2 Video Plugin listed. Right click on it and increase its priority until it is higher than the others listed (1 on my system).
This worked for me - with TMPGEnc 2.51.
Best of luck. -
In PowerDVD it says that its MPEG-2 for video and audio. I installed the mpeg2 file for tmpg but it just freezes the program up. what can work?
I just put the setting to -4, (I use -2 for it to work with avi's and it works good) and it loaded up but still said its invalid. What can I do to fix this?
I'm sorry idn't ask this part last time
why are you converting it? you never saidWe were all NEWBIES once and the only stupid question is the one that's not asked? -
because the file isnt compatible with stand alones. I want to be able to play it on a stand alone player
Problems with PS3 Compatibility
By AjzRide in forum Blu-ray RippingReplies: 4Last Post: 30th Jul 2009, 08:32 -
Premiere Pro CS3 MPEG-2 Compatibility
By cyberboy in forum Newbie / General discussionsReplies: 3Last Post: 1st Dec 2008, 13:58 -
problems with avc to mpeg-2 in tmpgenc xpress 4.0 - more than 3x run time?
By NoFace in forum Video ConversionReplies: 3Last Post: 18th May 2008, 21:01 -
TMPGEnc Xpress, MainConcept, H.264 and QuickTime Compatibility
By PuzZLeR in forum Video ConversionReplies: 6Last Post: 27th Oct 2007, 04:05 -
TMPGEnc & EO Video mpeg-2 conversion problems
By jtalpur in forum Video ConversionReplies: 2Last Post: 28th Aug 2007, 15:46
