Hi,
I know little about video processing so please excuse my ignorance. I am using an Apple Computer and I have been looking through some old hard drives and have come across several iMovie v1 and 2 project folders. These projects pre-date iMovieHD and the most recent version of iMovie will not import these projects claiming that it is unable to find any usable video. So a big thanks to Apple for that! However, some digging inside the folders reveals a number of files named "clip nn.dv".
The source of these files was a Sony TR805E Hi8 camera. I believe that I digitised the analog data by connecting the camera to a newer Sony digital camera that digitised the signal while passing it up to the computer running iMovie. I have discovered that an older copy of QuickTime will open these .dv files and will allow me to export them to a new file format. I am seeking advice on what settings I should use so that the clips may be edited in the future for viewing on an HDTV. Quicktime7 allows the files to be saved to a multitude of formats including "Apple Intermediate Codec".
Now for my questions:
1) Am I correct in thinking that I should use the Apple Intermediate codec?
2) Should I tick the "Deinterlace Source Video" option ?
3) The default dimensions are 768x576, are these large enough ? (I read that Hi8 records at 400 lines)
4) There is an option to use HD size with letter boxing. Is there any advantage to adding the letterbox at this stage or should it be added later once the clips have been assembled into a movie?
5) What software would you recommend to edit and assemble the clips given that I am less than thrilled with iMovie?
Simon
Results 1 to 1 of 1
Noob here, Looking for suggestions on how to capture Hi8 tapes for editing
By lonski in forum Newbie / General discussionsReplies: 0Last Post: 27th Apr 2019, 15:43 -
hi8 and Digital Hi8 backup help needed.
By SQWIB in forum Capturing and VCRReplies: 5Last Post: 8th Jul 2016, 18:13 -
Reading and storing smtpe code of video playing on computer
By jabellas in forum Newbie / General discussionsReplies: 0Last Post: 22nd Oct 2014, 12:27 -
Can someone mentor me about capturing and storing streaming video?
By gastrof in forum Newbie / General discussionsReplies: 4Last Post: 15th Oct 2014, 18:54 -
Storing video on BD-R using laptop that doesn't have blu ray drive
By TB2XSBW in forum Authoring (Blu-ray)Replies: 1Last Post: 8th Oct 2014, 22:59
