  1. Everything looks good during a download, until you see 100%, then you see "saving". During the "saving" process, the download stops, and you see "network error". Sometimes, this does not happen with smaller files, like 400mb, but it always happens with larger ones, like 2GB. Why? Solution?
  2. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    That plugin has some weird bug,where it fail to "save" the file as a media playable file.Even if you add container (.mp4 or .ts or whatever),it will say "network error" or will save some sort of "system file" type thing. It was easier just to execute CMD with youtube-dl or streamlink. In youtube-dl case i like that if the file download stops at some % (e.g. 75%), by then executing same command it will continue where it left,unlike that plugin.
