Hi, I want to make a multitrack videocd from 6 mpegs files that I have, but I have a problem because some of the files are in NTSC and the rest in PAL. Can I make a mixed PAL / NTSC multitrack videocd or I wil have to convert all the files to the same format?
Thanks in advance
Never done it to be honest, but I don't see why a VCD can't hold both formats at the same time. Just make sure your TV can support them and it should be fine. Might still be a good idea to burn to cd-rw first (if your player supports it).
It does work - the only thing you need to be careful of is whether your DVD player can automaticlly switch formats on the fly. Most can these days though but older models will usually lock onto the first format and give odd results with the other format. As the_macman suggested go for a CD-RW if you can first but you should be OK.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
