Ok, here it is. This one is a bit longer, 3 different scenes, so you can have an idea of what I'm working with.
Results 31 to 48 of 48
In cases like this it pays to analyze the source frame by frame in Virtualdub2 (it usually only takes a minute or two),
I used an old filter called viewfields for the split display on the right. It shows to two separate fields (temporally displaced)
derived from the frame on the left
So because of these frames you need to do some more things before re-encoding (In this case field match and decimate) -
I understand that; which is why I already did IVTC on this in my original script. Plus I did some basic color work. My only issue is getting this filter to work without these side effects.
What side effect ? Was there something in the video I uploaded ? What frame number ?
davexnet, the side effect of temporaldegrain2, remember our original conversation??? The ghosting!
Ok, I don't understand what you did. Did you use temporaldegrain2 on this? If so, what are your settings?
Ok, I see the script. But why is it that you're not getting the side effects I'm getting? And why did you resize it?
Here it is:
MPEG2Source("blah.d2v", cpu=0)
TFM(d2v="blah.d2v")
TDecimate(mode=1)
#clean up junk
Temporaldegrain2()
#colorwork
Tweak (sat=0.72)
Chromashift()
MergeChroma(awarpsharp2(depth=20))
#sharpen and AA
Toon()
Santiag(2,2) -
This script runs really slowly on my PC, barely 1 fps.
But it seems to work. If you're still having the problem comment out everything
after Tdecimate and look at it frame by frame in Virtualdub2. Verify the frame rate is 23.976 -
With that script and multithreading enabled I get about 6 fps (5 fps encoding with x264), no ghosting.
By the way, the video really needs flicker reduction. -
Good morning all
I am a novice on the forum, I need help to denoise videos, I install Avisynth + and copy the "TemporalDegrain-v2.avsi" in my folder C: \ Program Files (x86) \ AviSynth + \ plugins +.
here extract from my script
SetFilterMTMode("QTGMC", 2)
FFmpegSource2("video.avi", atrack=1)
AssumeBFF()
QTGMC(Preset="Slower", FPSDivisor=2,)
TemporalDegrain2(grainLevel=true)
Sharpen(0.55, MMX=True)
BilinearResize(720, 576)
Crop(18, 18, -14, -12)
Spline64Resize(720, 576)
Prefetch(10)
"Script error
yntax error line 4, column 37" !??
help me please ! -
"Script erroryntax error line 4, column 37" !??QTGMC(Preset="Slower", FPSDivisor=2,)
remove " , "責任者-MDX
DVD causing Incorrect Disc error, when previously no error
By bishopmaryb in forum Authoring (DVD)Replies: 2Last Post: 16th Jun 2018, 21:24 -
Downloading HDS stream gives forbidden error or auth token error
By vishiwig in forum Capturing and VCRReplies: 1Last Post: 10th Jun 2017, 17:45 -
Error When Trying to Use Fileboom Site - Error Message Appears
By devilcoelhodog in forum Newbie / General discussionsReplies: 5Last Post: 13th Feb 2017, 08:34 -
VirtualDub error: Video Compressor error: The source image format is not
By maddie in forum Capturing and VCRReplies: 1Last Post: 26th Apr 2015, 12:12 -
Mediacoder ERROR !
By vickynash in forum Newbie / General discussionsReplies: 6Last Post: 28th Jul 2014, 16:35
