https://gyazo.com/21c777e5a4234e3890a4ee5785e99eab
what is this transition called? or a link how to make it on some editing software (prefer svp)
It's like a swish pan (where the speed of the pan creates motion blur with hides the cut), so I'd call it a spinning swish-zoom.
No idea about working with that particular software.
Create the gradually increasing blur, apply a zoom and a spin. Render it. Do the same for the clip on the other end. Then cut out the middle and butt the 2 together at the point of most blur, or however the timing works out best. Change the order of FX if it looks better (e.g Z-in, Spin, Blur).
Harkens back to 60's Batman logo transitions.
Scott -
A swish-pan is like the old batman cuts. Like what Scott says.
What is this effect called?
By Rettu in forum EditingReplies: 2Last Post: 12th Apr 2019, 22:01 -
How is this effect called and created in an NLE?
By flashandpan007 in forum EditingReplies: 3Last Post: 25th Mar 2019, 14:21 -
By Anonymous754 in forum Newbie / General discussionsReplies: 17Last Post: 11th Jun 2018, 20:06 -
What is this called [see screen]
By RBCC in forum Newbie / General discussionsReplies: 4Last Post: 2nd Apr 2016, 03:34 -
What's this audio effect called?
By langf in forum AudioReplies: 1Last Post: 30th Apr 2015, 16:52
