Hi There,
I'm capturing from VHS with a tv-card(BT8.. chip).
Picture quality is fine.
However, I'm getting this irritating Scratching/Ticking
sound whenever someone speaks ... ??
My sound is from Audio out on VHS to Line-in on SB Live card.
I am encoding in PCM.
Any Ideas ??
Regards,
Gavin
Do you happen to have a VIA MVP3 chipset?
My sound blaster live gave me terrible trouble on my old K6-3 system with the MVP3 chipset. Everytime I captured I got the sort of horrible noise's you described. The only way I got rid of it was when I upgraded to a Duron with the KT133 chipset, and I have heard of people having the same problem with the SB live and the MVP3 chipset.
If you don't have MVP3, you could try to lower the volume on the line-in to about 70%. But if you do have MVP3, then I think you're in trouble.
Tool Man.
I have a problem with mp4 files in virtualdub, slow motion audio.
By barbur in forum Newbie / General discussionsReplies: 5Last Post: 12th Feb 2012, 14:16 -
Audio - Video Sync Problem - VirtualDub
By cyberlion in forum EditingReplies: 13Last Post: 16th Jul 2010, 08:51 -
VirtualDub audio problem
By wcdeich4 in forum EditingReplies: 9Last Post: 10th Dec 2009, 22:57 -
Problem with Append AVI in VirtualDub - Audio of Sync - How Fix?
By Chakra in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 19:00 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08
