Hi
I used the option in SubtitleEdit to remove heairing impaired, but there are still a dozen + lines that are not removed.
Is the "br" tag the problem?
How do I fix this?
Oh, I just saw the "only if text is uppercase" option... blind me.
	As I'm sure you know the "br" tag is a visible representation of a line break.
 Show us a hearing impaired line that doesn't get removed.
  Program to remove streaks, lines, spots from VHS?By Master Tape in forum RestorationReplies: 10Last Post: 10th May 2020, 16:42
  Can I remove tracking lines?By jcool26 in forum RestorationReplies: 7Last Post: 22nd Jul 2016, 11:14
  How to remove tracking linesBy jcool26 in forum Newbie / General discussionsReplies: 1Last Post: 1st Jul 2016, 22:37
  How can I remove these lines?By killerteengohan in forum RestorationReplies: 15Last Post: 16th Mar 2015, 04:19
  how can I remove interlaced lines from 1080p m2ts file?By Tomaquet in forum RestorationReplies: 18Last Post: 11th Feb 2015, 04:50
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			![[ss]vegeta is offline](images/statusicon/user-offline.png)
			![[ss]vegeta's Avatar](customavatars/avatar177118_5.gif)
