  1. Hello, dear all.
    ---> https://www.youtube.com/watch?v=htVjVUXf2n4
    I could download such link using Tubedigger. But using other programs I could not.
    How can I do it using youtube-dl only? The highest resolutions available.
    Thanks for your tips!
    Best regards.
    devil (johner)
  2. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    So,since it's geoblocked (at least to me),you would need to know in which country/countries it's not geoblocked,so using this link:
    https://unblockvideos.com/youtube-video-restriction-checker/#url=htVjVUXf2n4
    You see that it's viewable in Brazil.
    With youtube-dl now you have 2 options. Either using a brazilian VPN or trying bypassing the geo-restriction with in-built geo-bypass, or adding a proxy to the command line.
    If you use VPN,then there's nothing to add really,just call the youtube-dl with the link.
    Otherwise with no VPN
    Option #1:
    C:\youtube-dl>youtube-dl --geo-bypass-country BR https://www.youtube.com/watch?v=htVjVUXf2n4
    [youtube] htVjVUXf2n4: Downloading webpage
    [youtube] htVjVUXf2n4: Downloading video info webpage
    ERROR: The uploader has not made this video available in your country.
    It works only in few % of cases (mostly with not youtube links)
    Option #2 - adding proxy from e.g. http://spys.one/free-proxy-list/BR/
    The code looks like:
    C:\Users\tripl\Desktop\Tools\Download tools\youtube-dl>youtube-dl --proxy https://186.229.25.18:8080 https://www.youtube.com/watch?v=htVjVUXf2n4
    [download] Destination: A mente do matador - Parte 1 _ Conexão Repórter (20_05_19)-htVjVUXf2n4.f136.mp4
    [download]   1.9% of 218.56MiB at 590.51KiB/s ETA 10:24
    It downloaded a 720p video to me.
    It always picks the best quality,however you can always check the best quality with -F before download:
    C:\youtube-dl>youtube-dl --proxy https://186.229.25.18:8080 -F https://www.youtube.com/watch?v=htVjVUXf2n4
    [info] Available formats for htVjVUXf2n4:
    format code  extension  resolution note
    140          m4a        audio only DASH audio  132k , m4a_dash container, mp4a.40.2@128k, 36.36MiB
    394          mp4        256x144    144p   89k , av01.0.05M.08, 30fps, video only, 20.38MiB
    160          mp4        256x144    144p  111k , avc1.4d400c, 30fps, video only, 12.61MiB
    278          webm       256x144    144p  123k , webm container, vp9, 30fps, video only, 26.33MiB
    395          mp4        426x240    240p  195k , av01.0.05M.08, 30fps, video only, 31.11MiB
    242          webm       426x240    240p  223k , vp9, 30fps, video only, 30.78MiB
    133          mp4        426x240    240p  245k , avc1.4d4015, 30fps, video only, 22.79MiB
    396          mp4        640x360    360p  354k , av01.0.05M.08, 30fps, video only, 55.45MiB
    243          webm       640x360    360p  410k , vp9, 30fps, video only, 51.12MiB
    134          mp4        640x360    360p  632k , avc1.4d401e, 30fps, video only, 57.73MiB
    397          mp4        854x480    480p  690k , av01.0.05M.08, 30fps, video only, 98.12MiB
    244          webm       854x480    480p  752k , vp9, 30fps, video only, 75.28MiB
    135          mp4        854x480    480p 1159k , avc1.4d401f, 30fps, video only, 112.85MiB
    247          webm       1280x720   720p 1509k , vp9, 30fps, video only, 132.97MiB
    136          mp4        1280x720   720p 2330k , avc1.4d401f, 30fps, video only, 218.56MiB
    18           mp4        640x360    medium , avc1.42001E, mp4a.40.2@ 96k, 120.24MiB
    43           webm       640x360    medium , vp8.0, vorbis@128k, 186.96MiB
    22           mp4        1280x720   hd720 , avc1.64001F, mp4a.40.2@192k (best)
    If you want f.e. webm 1280x720, then next time add to the command "-f 247+140" (without quotes).
    P.S. if you're not geblocked and it still doesn't work for you,yu might want to make sure you have latest youtube-dl by calling -U in the commandline
  3. @ Sviests
    Thanks a lot! Very nice tips!
    Using Tubedigger I could pick 720p video to me.
    Other programs failed to get the videos in such "specific" link.
    I have used other programs without success in such "specific" link: 4K Video Downloader ( got only video file, not sound inside ), TVideoDownloader ( only got a very small and invalid file ) and DLNow Video Downloader ( do not get any file ).
    Does it possible to find a way for the programs above work on such link? Or only using youtube-dl + your tips explained previously?
    Thanks again for your help!
    Best regards.
    devil (johner)
  4. Average video editor Sviests's Avatar
    Sep 2018
    USA,Sweden
    Streamlink works too,but it's similar to youtube-dl.
    Also there is a VideoDownloadHelper plugin for firefox/chrome,which should download those too (only exception that you might need using an unblocking addon (like Hola plugin for firefox f.e.))
    Other than that i don't really see a chance. (for me usually youtube-dl/streamlink is fast and good enough,no need for extra work and no need for other tools.)
  5. Hola is reputed to be crapware.
