  1. I'm currently in the midst of building a capturing machine, but the fan that comes with the 9600 Pro is rather flimsy and i hear the chip can overheat and cause issues (Is this true or just hyperbole?) So i had got a VGA cooling fan from China, but it's so poorly designed that it doesn't line up with the holes on the 9600 as chip batteries keep getting in the way, when it states on the box it's compatible with the model... Anyway is there a better VGA cooling fan (ideally one with nylon pins so it just clicks into place, as the screws that came with the one i got were so tiny that they didn't even fit in the holes.. or should i just stick with the fan that came with the 9600, and hope for the best?
    canada
    Thread moved to the computer forum.
