I'm getting the same error regarding appending file 2 to file 3, and then the rest of them are fine.The track number 0 from the file '2.mp4' can probably not be appended correctly to the track number 0 from the file '1.mp4': The codec's private data does not match (lengths: 44 and 44). Please make sure that the resulting file plays correctly the whole time. The author of this program will probably not give support for playback issues with the resulting file.
MediaInfo seems the same:
Code:General Complete name : 1.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (mp42/mp41/isom/avc1) File size : 47.2 MiB Duration : 2 min 32 s Overall bit rate mode : Variable Overall bit rate : 2 592 kb/s Encoded date : UTC 2013-04-23 02:26:50 Tagged date : UTC 2013-04-23 02:26:50 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 2 min 32 s Bit rate : 2 426 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (29970/1000) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.088 Stream size : 44.2 MiB (94%) Writing library : x264 core 129 r2245 bc13772 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=90 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=2426 / ratetol=1.0 / qcomp=0.60 / qpmin=5 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=3750 / vbv_bufsize=12500 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2013-04-23 02:26:50 Tagged date : UTC 2013-04-23 02:26:50 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 2 min 32 s Source duration : 2 min 32 s Bit rate mode : Variable Bit rate : 158 kb/s Channel(s) : 2 channels Channel positions : Front: L RAnd even the non-matching numbers are identical. It creates the file but it won't play back properly, as implied.Code:General Complete name : 2.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (mp42/mp41/isom/avc1) File size : 204 MiB Duration : 10 min 58 s Overall bit rate mode : Variable Overall bit rate : 2 599 kb/s Encoded date : UTC 2013-04-23 13:14:45 Tagged date : UTC 2013-04-23 13:14:45 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 10 min 58 s Bit rate : 2 437 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (29970/1000) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.088 Stream size : 191 MiB (94%) Writing library : x264 core 129 r2245 bc13772 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=90 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=2437 / ratetol=1.0 / qcomp=0.60 / qpmin=5 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=3750 / vbv_bufsize=12500 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2013-04-23 13:14:45 Tagged date : UTC 2013-04-23 13:14:45 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 10 min 58 s Source duration : 10 min 58 s Bit rate mode : Variable Bit rate : 158 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 spf) Compression mode : Lossy Stream size : 12.4 MiB (6%) Source stream size : 12.4 MiB (6%) Encoded date : UTC 2013-04-23 13:14:45 Tagged date : UTC 2013-04-23 13:14:45
Is there anything I can do to get file 2 to match the rest? Just trying to combine about ten shorter videos, with chapter markers in between.
Results 1 to 14 of 14
Re-encode to make it match the first. MediaInfo doesn't show detailed info about H.264 headers (PPS/SPS). You'd need a more in-depth H.264 analyzer like e.g. Zond. Maybe x264's header optimization resulted in different headers (--stitchable option didn't exist yet in revision 2245).
Workaround can be to spread SPS/PPS to every keyframe. Try ffmpeg's concat demuxer instead of mkvmerge for appending (there are more options, e.g. run dump_extra filter filter on all source files individually, then append while ignoring mkvmerge warning). -
So I have to run that command on all of them, then the concat command? Is there a way to batch them, I have ten files here.
I would test with two files first. Then if you are successful try batching.
Code:md "work_folder" for %%a in (*.mp4) do ffmpeg -y -i "%%~a" -map 0 -c copy -bsf:v "h264_mp4toannexb,dump_extra=freq=k" "work_folder\%%~a" (for %%b in (*.mp4) do @echo file '%%~b') > "work_folder\filelist.txt" pushd "work_folder" ffmpeg -y -f concat -safe 0 -i "filelist.txt" -c copy "..\output.mp4"
/edit:
FWIW: I see it's mp4 and not mkv. IIRC mp4 even "officially" allows multiple PPS/SSP and has a way to store them though I don't know which muxer/how. It's probably not needed to make it work but ...Last edited by sneaker; 27th May 2019 at 16:06.
The following is just some extra info. It's not required to solve the problem but can help find out why there are such problems with certain combinations of input files when appending.
Zond 265 demo/info can be found here.
But actually ffmpeg also has some features to print SPS/PPS: trace_headers bsf.
Code:ffmpeg -y -i "INPUT" -map 0:v -c copy -frames:v 1 -bsf:v trace_headers -f matroska NUL 2> headers.txt
With x264's header optimization "pic_init_qp_minus26" can differ even with the very same command-line. This can cause decoding problems when appending. You can search for it directly:
Code:ffmpeg -y -i "INPUT" -map 0:v -c copy -frames:v 1 -bsf:v trace_headers -f matroska NUL 2>&1 | findstr "pic_init_qp_minus26"
When encoding with x264 header optimization can be turned off via --stitchable. -
The dump_extra batch file seems to have fixed the issue. I still get a warning but the file plays back just fine.
I just realized there is no reason to put this into separate ffmpeg calls. So a short batch would be simply:
Code:(for %%a in (*.mp4) do @echo file '%%a') > "filelist.txt" ffmpeg -y -f concat -i "filelist.txt" -map 0 -c copy -bsf:v "h264_mp4toannexb,dump_extra=freq=k" "output.mp4"
Creating the work folder with the individual parts allows me to go back to MKVtoolnixGUI and append them with chapter markers, though. The single output.mp4 file your command creates has no chapters.
sneaker @9, that batch file to merge mp4 files is very useful - thank you!
Is there any chance you could adapt it to merge MKV files? (Just changing mp4 to mkv throughout doesn't work.
(Error parsing bitstream filter sequence 'h264_mkvtoannexb, dump_extra=freq=k': Bitstream filter not found.) -
Oops, the modification is easy.
Code:(for %%a in (*.mkv) do @echo file '%%a') > "filelist.txt" ffmpeg -y -f concat -i "filelist.txt" -map 0 -c copy -bsf:v "h264_mp4toannexb,dump_extra=freq=k" "output.mkv"
Splitting into 3, editing 1, can't rejoin bc private codec data don't match
By Travillion in forum EditingReplies: 57Last Post: 8th Aug 2018, 15:34 -
H264 2pass messed up private data for joining files
By FireEmerald in forum EditingReplies: 11Last Post: 22nd Aug 2017, 10:32 -
Video Codec "Private Data" Does Not Match During Join
By Shoal in forum Newbie / General discussionsReplies: 23Last Post: 14th Jan 2016, 14:42 -
"The codec's private data does not match"
By Elegant in forum EditingReplies: 24Last Post: 30th Sep 2015, 23:21 -
codec private data issue - ffmpeg CRF15 and CRF18 in MKV files
By jack616 in forum Newbie / General discussionsReplies: 3Last Post: 1st Sep 2015, 14:32
