    May 2019
    Los Angeles
    Hi can anybody help me find a Digital Voodoo SD 10bit codec for Mac. I have some old footage I never converted back then and it seems the company is gone and so is the codec. Would help out a lot. Thanks. Thomas
    canada
    Thread moved to the mac forum where you can get more help.
    Feb 2006
    here - https://discussions.apple.com/thread/2579411
    Aug 2006
    That discussion suggests a link for downloading codecs, http://www.bluefish444.com/support/downloads/codecs_macosx.asp, but it appears to be a dead end. The page that appears today when someone clicks the link is a download page which contains no links to any codecs.
    May 2019
    Los Angeles
    Is also mentions as per their SUPPORTED HARDWARE
    Epoch | Horizon, Epoch | Core, Epoch | Ultra, Epoch | 2K Horizon, Epoch | 2K Core, Epoch | 2K Ultra, Create | HD, Create | 3D, Create | 3D Ultra, Epoch | 4K Supernova, Epoch | 4K Supernova TURBO, Epoch | 4K Supernova S+, Epoch | 4K Supernova S+ TURBO, Epoch | Neutron, Epoch | 4K Neutron, Epoch | 4K Neutron TURBO
    No Digital Voodoo?
    May 2019
    Los Angeles
    Awesome, Thanks! One step accomplished. Now I need to set up 10.4 to install (expand). Thanks for the help.
