Hello,
Is there a way to convert my old mp3/cdg collection to a more standard playable format like mp4/avi or wmv?
So far i have been searching the forum but only found threads that are over 15 years old (with none of the given links working anymore). cdg2avi doesnt seem to exist anymore either.
Kanto and Power cdg converter advertise as freeware but aren't (and even the trial version ends up with some unplayable file)
There seems to be a way for VLC player to convert, but it crashes almost instantly when you press convert (a bug that according to Google has been reported over 3 years ago)
So any help or tips on how to convert the 2 files to a single file, or even how to convert the old cdg format itself to avi or mp4 without sound, would be very helpfull.
took about 5 seconds to search "cdg to avi" and pick ~8th item "PowerKaraoke". https://www.powerkaraoke.com/.
Site explicitly says has tool to do just that (as well as to MPEG).
Scott -
It took even less seconds to find out it isnn't freeware...
@jagaboo : Thanks i will try that! Too bad that VLC still cant convert without crashing though..
Edit: It works! I only need to tweak some settings now so the final image gets less compressed (and looks sharper). Thanks again for the help.Last edited by NickvTd; 23rd May 2019 at 00:37.
Trying to backup a Blu-ray disk to MP4 or MKV with freeware
By zanthal in forum Blu-ray RippingReplies: 6Last Post: 1st Jan 2016, 04:49 -
Splitting an MP4 Video Freeware?
By simple times in forum EditingReplies: 4Last Post: 27th Dec 2015, 03:11 -
what is best mkv to mp4 converter
By xurimx in forum Video ConversionReplies: 10Last Post: 1st Sep 2015, 18:59 -
TS to AVi/MP4/WMV/HD doesn't work... :(
By langf in forum Video ConversionReplies: 9Last Post: 19th Apr 2015, 12:44 -
Smart rendering mpeg-2, wmv, avi, mp4 and mov frame accurately?
By jedi55 in forum EditingReplies: 2Last Post: 14th Jun 2014, 18:26
