Hey guys, I'm trying to convert an uncompressed (raw) AVI file to uncompressed (raw) AVI. So, essentially, just converting it back to the same format to test if it works. I don't want to just copy the already working video steam.
The command I use is:
Am I using the correct command here? The output file is not viewable in the latest VLC player (v3.0.6). The codec information has the incorrect height too: codec information. The ffprobe output shows the same input and output format.Code:./ffmpeg.exe -i <input-filename> -f avi -c:v rawvideo -pix_fmt bgr24 output.avi
The sample AVI I got from this website (HD Uncompressed AVI link link on the site, in case anyone cares).
If anyone can help me, I would greatly appreciate it! Thanks.
Results 1 to 1 of 1
FFMPEG Only Converting at 1.5-2 FPS
By aaronc1976 in forum Video ConversionReplies: 4Last Post: 29th Aug 2016, 14:16 -
FFMPEG converting 4k MP4 files.
By Phillipj in forum Video ConversionReplies: 11Last Post: 30th Jul 2016, 16:07 -
Need Help Converting an AVI file from a CCTV system - Plays in WinMedia
By webby88 in forum Video ConversionReplies: 1Last Post: 10th Apr 2016, 13:08 -
The problem with converting ffmpeg
By Jamaika in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2015, 13:02 -
Trouble reading VTS_01_1 VOB file when converting to AVI
By LouB in forum Video ConversionReplies: 2Last Post: 8th Aug 2014, 06:21
