I have a bunch of videos that were recorded in India and the Middle in the PAL format. I am currently in the USA and wanted to convert them to digital that I can share with the rest of the family.
I have my old VCR from my time there, which is a Sharp multi format player, so it can play PAL/SECAM/NTSC/MESECAM format tapes.
I am looking to purchase Roxio Easy VHS to DVD for the software/hardware capture side of things. Ill be using a spare machine with Windows 7, since people have had the most success with that version of the software and Windows.
Will I need a PAL to NTSC converter like this in between the vcr and the Roxio hardware ?
Do I need any other hardware ? Ive been reading about needing a SCART card, but cant get more information.
Results 1 to 10 of 10
First, you need to determine whether the Roxio device supports PAL. The guide implies so but I can't find any documentation. If it does, then let your VCR output native PAL and you will be fine.
Otherwise, you must determine if your Sharp converts to true NTSC or if it outputs PAL60, a signal which many TVs will play but which will be black-and-white through the digital converter. -
That's not an analog PAL to analog NTSC converter. It's an HDMI to composite converter that supports both PAL and NTSC output. Cheap PAL/NTSC converters deliver crappy output. You should buy a capture device that supports PAL capture so you don't need a converter. Something like the Diamond VC500. The Hauppauge USB Live2 may support PAL too -- but I don't see PAL mentioned in the description at their web site.
Whether you need a SCART to composite or s-video adapter depends on what outputs your VHS deck has. You want to use s-video whenever possible.
If your tapes aren't in great condition you may need a time base corrector.Last edited by jagabo; 20th May 2019 at 13:34.
Most if not all media players, smart devices and smart TV's playback PAL digital files fine, No need to convert to anything no matter what country you are in, That was back in the day when hardware such as VCR's and CRT TV's were locked to a standard, Not anymore now.
During playback. If you are dropping a lot of frames, or they jump around or wiggle back and forth a lot, then you need TBC processing. This has more to do with the quality of the recording itself rather than the physical tape, although if the tapes are very old, shrinkage can be a factor.
The UK and European flavors of PAL differ in their transmission characteristics, all of which are discarded when the signal is recorded to tape. So you shouldn't have any problems if the recordings are true PAL50.
VHS to Digital conversion which capture card?
By RS456 in forum Capturing and VCRReplies: 3Last Post: 29th Apr 2019, 08:50 -
VHS conversion to digital
By RS456 in forum Capturing and VCRReplies: 40Last Post: 11th Jan 2019, 11:09 -
How to get PAL VHS to digital
By graymoment in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2017, 15:10 -
PAL VHS tapes to digital conversion help
By alfaromeo155 in forum Video ConversionReplies: 22Last Post: 31st Jan 2015, 21:35
