My problem:
Even with all recommended "Trade quality for performance" options selected and fairly tame filtering I still get low performance (~15 fps when I should be getting at the very least 24, i.e, 10 frame drops per second). I really doubt a setup this old and widely-used takes hardware this good to run minimally well.
My bulid: ~2-3 year old ASUS gaming laptop withProbably useful info:
- MPC-HC with LAV, madVR, CCCP, XYsubfilter and ASSmod (because they don't always both work)
- i7-6700HQ @ 2.60 GHz
- GTX 960 (4 GB)
- 16 GB DDR4 RAM
- 1TB HDD and 128GB SSD
- Windows 10
- It uses up nearly all of my GPU's time (yes, the dedicated GPU) but not so much the CPU
- Most of the GPU usage is for 3D (and a little bit for decoding)
- I have Vsync enabled but it doesn't seem to improve performance at all
- Integrated Graphics don't do anything (can't use both GPU's at once for the same thing)
- Render time is fairly low at the start of the video file leading me to suspect the GPU stores unnecessary frames (maybe changing GPU flush settings could help?)
- madVR takes too long to render the frames, which is the likely cause of his issue.
Using CTRL+J I see frame render time usually hovers 70ms when it should take at most 1/24 ~ 42ms
Here's a link to my madVR and LAV settings
Your settings are pretty advanced. Create a folder called "ShowRenderSteps" within the madvr folder. Then the OSD (CTRL+J) will show where the time is spent.
You say at the beginnung of the video render times are ok, then too long. Is your GPU being throttled because it overheats/uses too much power? Did you monitor your GPU clock rates/power state yet? -
GPU doens't seem to be throttled. Core clock stays pretty much constant, not to mention I have no energy saving options enabled, so I doubt it's a power issue.
"ShowRenderSteps" seems pretty useful but I can't see all of the text (too many lines). Any way I can display all of them / log them?
Saving current frame w/ Potplayer + madVR, not saving madVR effects
By LJay in forum Newbie / General discussionsReplies: 3Last Post: 26th Jul 2017, 16:14 -
Intermittent low upload queue in MPC-BE / madVR
By GatesDA in forum Software PlayingReplies: 3Last Post: 19th Jul 2017, 09:11 -
Frame drops when using MPC + madVR, no matter what I do.
By fighuass in forum Software PlayingReplies: 11Last Post: 22nd Feb 2017, 08:03 -
MPC BE with madVR Help
By Jackpison in forum Newbie / General discussionsReplies: 2Last Post: 14th Feb 2017, 04:01 -
MPC-HC 32-bit + madVR = frequent crashes in fullscreen
By Ygramul in forum Software PlayingReplies: 7Last Post: 5th Aug 2015, 09:35
