Hi,
I intend to buy a new Dell XPS 13 9380 (2019), and have the choice between i5-8265u with 8GB RAM and i7-8565u with both 8 and 16GB models.
Since all only have Intel HD 620 graphics, is it still worth it to get the more expensive 16GB model for video editing or will the processor and graphics be the bottleneck? What real life benifits will I really see or am I just wasting money? I edit mostly 1080p files.
Thanks in advance for all good feedback.
For anything that has to do with greater than average computation, such as graphics, video, or 3d...
The answer is YES.
Scott -
8GB vs 16GB is pretty much deciding on if you need to close everything else down while editing or being allowed to have up web browsers and other stuff. You should be able to edit 1080p just fine on 8GB assuming it's the only thing running. That Intel HD 620 graphics is going to hold you back but to be expected on a Laptop. Adobe PP and Adobe AE are mostly CPU focused while Resolve is more GPU focused.
Dell AC Adaptor compatibility, (Amps and Volts ) for Dell D620 laptop
By visionman in forum ComputerReplies: 7Last Post: 27th Dec 2017, 10:25 -
Buying a laptop with 32 bit OS
By shans in forum ComputerReplies: 12Last Post: 18th May 2016, 22:18 -
copy same software installation from laptop A to laptop B ?
By vhelp in forum ComputerReplies: 9Last Post: 7th Oct 2015, 13:21 -
Car Crash Cam/ SanDisk 16GB Micro SD
By VideoChunkster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 22nd Jun 2015, 17:56 -
iPad Mini 16GB Model MF432LL/A
By vhelp in forum Portable VideoReplies: 1Last Post: 10th May 2015, 20:43
