I've read that the difference between UK PAL and Continental PAL is the carrier frequency used for the audio. But is that referring to:
- the (now former) analogue TV broadcasts
- the encoding on the tape
- or both?
I am aware of the VHS PAL I standard for the UK and the VHS PAL B/G etc standard in continental Europe.
According to these links, if the SCART output is used, then the audio is available. The links say that the difference in audio encoding is only related to the RF (Radio Frequency) signal i.e. broadcasts:
- VHS tape recordings in the U.K. where else do they work? - https://forums.digitalspy.com/discussion/124554/vhs-tape-recordings-in-the-u-k-where-e...e-do-they-work
- can I convert a PAL-B/G signal to a PAL-I signal? - https://www.avforums.com/threads/can-i-convert-a-pal-b-g-signal-to-a-pal-i-signal.84444/
My use case is for using a continental video player from Germany to play UK VHS PAL tapes and convert the video and audio digitally.
Setup:
- Model: JVC HR-S9600EU (not EK - UK) - one of the apparently higher quality machines, according to:
- VCR Buying Guide 1 - http://www.digitalfaq.com/forum/video-restore/1567-vcr-buying-guide.html
- VCR Buying Guide 2 - details of model codes such as EK and EU - http://www.digitalfaq.com/forum/video-restore/1567-vcr-buying-guide-2.html
- Canopus ADVC100 attached to computer via Firewire
PAL standard references:
From a former vhs trading perspective VHS recordings from the UK work on continental vcrs without any need to convert.
Same goes for commercial tapes. In my time, I acquired many VHS from all parts of Europe (except France) and these play fine on UK vcrs. -
I thought PAL-B/G/D/K/I are broadcast standards that has something to do with the type of tuner in the VCR during recording, It has nothing to do with the physical PAL VHS tape standard which is 625-line / 50 field (25 frame) per second with either HiFi Stereo or linear audio or both. I believe once the right tuner is used and the tape is recorded it becomes just PAL VHS, Anyone?
PAL is PAL. I've captured PAL tapes from all over the world.....from here in Germany.
Thank you for your input so far. I will be sure to confirm my findings that this is the case when I use the equipment.
VHS Tape (PAL) to DVD or the Best Format Conversion/Restoration Guide
By ConverterCrazy in forum RestorationReplies: 5Last Post: 18th Jun 2017, 21:33 -
How to get PAL VHS to digital
By graymoment in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2017, 14:10 -
Using PAL DV for VHS archiving
By Topsy in forum RestorationReplies: 11Last Post: 3rd May 2017, 12:36 -
How to tell a PAL and SECAM VHS signal apart?
By digicube in forum Capturing and VCRReplies: 20Last Post: 9th Feb 2017, 14:40 -
VHS Video Test Pattern Tape (PAL)
By VHSRules in forum Capturing and VCRReplies: 2Last Post: 4th Mar 2016, 10:05
