    Oct 2015
    Dublin
    Hi there.
    I want to pass 50 or 100 GB from drive E to drive I.
    Can you explain me how can I do that?
    Is there any guide STEP BY STEP to explain that?
    Windows 7 64bits and I attached the page of Disk Management.
    Thank you very much.
  2. Member DB83's Avatar
    Jul 2007
    Here:
    https://www.howtogeek.com/howto/windows-vista/resize-a-partition-for-free-in-windows-vista/ (applies to Win7 as well)
    Note the comment at the bottom of the screen about contigius space on the volume to expand.
  3. Since Windows' built in partition tool can only extend partitions into unallocated space immediately beyond the partition you can't do what you want without copying all the files from D and E elsewhere, deleting the partitions, extending I, recreating D and E (with the new size), and copying the files back.
  4. could be messy since partions are not next to each other.
    Dec 2005
    Canada
    The free program, Minitool Partition Wizard, says it can extend a partition by taking space from any other partition - on the same disk.
    "Extend Partition directly takes free space from any other existing partitions"
    https://www.partitionwizard.com/help/extend-partition.html
    Oct 2015
    Dublin
    Thank you everyone that helped me.
    I solved part of the problem with the advise of Jagabo. But one of partitions I didn't succeed because it said the partition is SYSTEM (?).
    So I used the link and its program that Sambat told me. And it functioned! Wonderful and simple program!
    Thank you again.
