I am seeing artifacts on the red colors very visibly. Most noticeably up against lines. They appear to be elsewhere as well, but on the reds they can't be missed. Here is an example image.
https://forum.videohelp.com/images/imgfiles/XquU6OR.png
https://forum.videohelp.com/images/imgfiles/Z55V1et.png
This kind of reminds me of halos, but my 2 halo removers I am trying are not really removing these much. They help a little, but it's not really doing so well. Chroma sharpening seems to help a little more when used as well, but again, it's not really removing it well enough.
Any suggestions on how I can remove or at least lessen the visibility much more?
I don't see artifacts at the lines,... can you highlight the artifacts you want to remove?
users currently on my ignore list: deadrats, Stears555, marcorocchini -
I see some sharpening halos. For example, to the left and right of the vertical black line on the red cape on Superman's right shoulder in the first image. The Y channel only has the halos along the X axis. The U and V channels on both axis. Something like:
Code:ImageSource("XquU6OR.png", start=0, end=23, fps=23.976) ConvertToYV24() Y = last U = UtoY() V = VtoY() Y = Y.dehalo_alpha(rx=3.0, ry=1.0, brightstr=0.8, darkstr=0.8) U = U.dehalo_alpha(rx=3.0, ry=3.0, brightstr=0.8, darkstr=0.8) V = V.dehalo_alpha(rx=3.0, ry=3.0, brightstr=0.8, darkstr=0.8) YtoUV(U, V, Y) -
I examined each channel individually.
Code:# assuming YV24 or YUY2 Y = GreyScale() U = UtoY() V = VtoY() StackHorizontal(Y, U, V)
Obviously, you can return any individual channel if you only want to see that channel.Code:# assuming YV12 Y = GreyScale() U = UtoY() V = VtoY() StackHorizontal(Y, StackVertical(U, V))
Help with H264 related artifact
By xAlienxx in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2016, 20:58 -
Your favorite Denoise/Artifact filter for VD?
By sum_guy in forum RestorationReplies: 9Last Post: 1st Jul 2015, 17:32 -
how to fix hd pvr rocket artifact fuzzy when different colors even with HD
By tj1080i in forum Capturing and VCRReplies: 1Last Post: 10th Apr 2015, 20:45 -
Name That Video Artifact!
By hizzy7 in forum RestorationReplies: 19Last Post: 23rd Oct 2014, 22:46 -
Is this true?Women see less colors than men, and they see washed out colors
By Stears555 in forum Off topicReplies: 5Last Post: 10th Jul 2014, 14:07
