Using the latest OBS under Windows, I am perplexed by the Stream area under Settings. They only let you specify a single token, and there is no way to configure multiple streams. Someone who actively uses OBS might be broadcasting on four or five systems over the course of a week. So the requirement that I have to go into these settings and manually reconfigure for each service is kind of ridiculous. Is there a way to enable saving multiple stream targets?
It looks like OBS is doing this through "Profiles" that you "Duplicate" and then "Rename". It's awkward, but it gets the job done.
How to capture anything with Obs Studio
By Baldrick in forum User guidesReplies: 1Last Post: 8th Sep 2021, 01:10 -
Color Ghosting with OBS
By ArctiCMooN in forum Capturing and VCRReplies: 25Last Post: 26th Feb 2019, 20:33 -
cut multiple segments from 1 video >>> stream copy app?
By savvyguy in forum Newbie / General discussionsReplies: 4Last Post: 21st May 2018, 13:31 -
Help with audio stream. m3u8 shows multiple .ts?
By nobodyhome in forum Video Streaming DownloadingReplies: 1Last Post: 14th Nov 2015, 10:34 -
multiple video stream transmission
By lily_zhang in forum Video Streaming DownloadingReplies: 4Last Post: 15th Jun 2015, 20:37
