Holy crap there is a lot of info here that I'm thoroughly confused now.
I have a Sony Sony DCR-HC40 and a TR3300 Hi8 camcorder. I have a lot of the Hi8 tapes and very few of the DV tapes. What I have done so far is basically run the Hi8 through the HC40 and the HC40 plugged into my PC via a cheap firewire PCIe card, so far so good and I can see the video on the screen. I've used sclive to capture the video into an AVI and looks OK, used VirtualDub and also works.
Question is will the video look better if I get a USB capture device and go directly from the Hi8 to the USB converter? Looking at the Elgato Video Capture - Digitize Video
It really depends on your eye. DV has lower color resolution that some people notice and some people do not. DV is also a lossy format; with a USB converter, you can save lossless or losslessly compressed — if that is important to you.
No idea if that is important, I'll have to research. Just trying to get a butt load of Hi8 tapes on to my file server so I can view them on my TV so I can remember what life was before kids
Keep in mind: whatever effort you put into it now will be reflected forever in your digital copies.
chinese usb 3 device capture
By codebox in forum Capturing and VCRReplies: 28Last Post: 21st Jul 2021, 16:20 -
Looking for a USB / RCA device suggestions
By dward1222 in forum Capturing and VCRReplies: 2Last Post: 18th Apr 2018, 14:05 -
DCR-TRV520 Digital8 playback issue with Hi8 tapes
By Harvey in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 21st Aug 2017, 15:42 -
Best video capture device with higher bit rate for converting Hi8 tapes?
By Studly in forum Capturing and VCRReplies: 10Last Post: 21st Jan 2015, 19:15 -
Happauge capture device issue (hi8 tearing image)
By Event3horizon in forum Capturing and VCRReplies: 46Last Post: 28th Jul 2014, 16:53
