I am learning OBS and a major usability issue I see is that you can hit the Start Streaming button and completely forget that you pressed it. Now you are broadcasting - potentially to a large audience - and you have no clue you are on camera. The obvious UI fix to this issue would be to have OBS flash an obnoxious red message somewhere near the top of OBS Studio that says "You Are Streaming Live!" Is there any way to configure it to do something like this?
Results 1 to 10 of 10
Doesn't the "Start Streaming" button's caption change to "Stop Streaming"?
Yeah but you have to look at the OBS GUI to see that. When in a full screen application, like a game, you don't want to have to tab out to look at it. I don't have an answer to this problem. When streaming with Nvidia ShadowPlay or AMD ReLive they both have a little bubble that pops up telling you if you are recording or streamng for a few seconds but OBS does not have this option.
The state is indicated as you say, but you really have to look for it. It would be so easy to miss this entirely, and there you are picking your nose in front of 10K people, totally unaware that you broadcasting live.
The analogy would be in the broadcasting industry. When you are broadcasting, there is a sign above the level of the camera that notifies everyone performing and everyone in the operations room that you are live on the air. For example:
[Attachment 49089 - Click to enlarge]
Everyone understands that without such a sign, disasters would happen all the time.
So there are numerous ways the OBS interface could address this. You could flash a red message at the top of the studio window. You could build a system gadget that flashes red during streaming and turns off when you stop. But there needs to be something there that you would have a hard time missing that tells you that you are in this very important state, which potentially compromises your privacy a lot. -
I'm guessing either that was meant for another thread, or it's just a troll. Ignore it. Nothing got moved, certainly.
In the broadcast industry, they don't just rely on the red light, they have round-trip CONFIDENCE monitors (aka TVs that are picking up the output signal to show if your broadcast is making it out there).
Do the same thing.
Next to your streaming setup, put a computer that is set to receive that/those stream address(es). If something shows up, you'll know immediately (well, within ~35seconds - latency!).
But honestly, I suggest you stop picking your nose in front of cameras anyway.
Scott -
AFA record/stream lights go: PunchLight, Delcom Visual Signal Indicator, or Kuando Busylight are some (USB based). Don't know if they will work with OBS though.
How to capture anything with Obs Studio
By Baldrick in forum User guidesReplies: 1Last Post: 8th Sep 2021, 02:10 -
Color Ghosting with OBS
By ArctiCMooN in forum Capturing and VCRReplies: 25Last Post: 26th Feb 2019, 21:33 -
How to remove annoying "Press Esc to ..." message in Flash Video
By roma_turok in forum User guidesReplies: 517Last Post: 23rd Oct 2017, 11:09 -
Potplayer Display Title/OBS
By tippysweet in forum Video Streaming DownloadingReplies: 4Last Post: 13th Nov 2014, 02:24 -
How to record streaming flash video, edit and save as AVI, MP4, FLV,etc.
By Baldrick in forum User guidesReplies: 3Last Post: 20th Sep 2014, 15:06
