    Aug 2011
    South Carolina
    Ok, I am experimenting a little. I created a m3u8 file along with a few .ts files from an RTMP stream (OBS).
    How can I use ffmpeg to create an MP4 out of them?
    Thanks,
    Ray
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    ffmpeg selects the decoder on its own, so any supported input file is basically the same. You would only specify the output parameters.
    use defaults
    ffmpeg -i input.m3u8 output.mp4
    or specify much
    ffmpeg -i input.m3u8 -c:v libx264 -preset medium -crf 18 -vf format=yuv420p -c:a aac -b:a 160k -movflags +faststart output.mp4
    or copy streams as-is
    ffmpeg -i input.m3u8 -c copy output.mp4
    if it breaks, then try in two steps, via MKV:
    ffmpeg -i input.m3u8 -c copy output.mkv
    ffmpeg -i input.mkv -c copy output.mp4
    Aug 2011
    South Carolina
    Thank you for the reply. Working great!
    Ray
    Aug 2011
    South Carolina
    One other question. When I create a video using my samsung S8 and the ManyCam app, when I turn the phone side ways, the video on screen follows, but the subsequent mp4 does not? So basically portrait works in the mp4 but landscape does not?
    Ray
  5. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    ffmpeg -i intermediate.mp4 -vf "transpose=dir=clock" -c:a copy output2.mp4
    where
    "transpose=dir=cclock_flip" = 90°CounterCLockwise and Vertical Flip (default)
    "transpose=dir=clock" = 90°Clockwise
    "transpose=dir=cclock" = 90°CounterClockwise
    "transpose=dir=clock_flip" = 90°Clockwise and Vertical Flip
    "transpose=dir=clock,transpose=dir=clock" = 180°
    In automated situations, it is possible to make exceptions for either landscape or portrait. transpose=dir=clock:passthrough=portrait
    Aug 2013
    Arizona
    where
    In automated situations, it is possible to make exceptions for either landscape or portrait. transpose=dir=clockassthrough=portrait
    So does this compensate for portrait and landscape in the same video? So if part of the video is portrait but then it flips to landscape and you have have to tilt your head to watch it, does it turn it?
  7. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    No. The whole clip is treated the same as the first frame.
