I have a couple of Intel CPU coolers around that I never used. Both are model E97378-001 for LGA1150, but have slightly DIFFERENT specifications, one is DC12V 0.28A and one DC12V 0.60A. Otherwise they seem identical in construction, made of aluminum with a copper core, but from different manufacturers. I am assuming that the second one has a faster fan and is intended for a more powerful CPU, but it came with a Pentium, while the first one came with an i5. What do you think?
Results 1 to 12 of 12
I'm guessing that each one was probably the cheapest cooler that fitted the general spec required that Intel could purchase that day. Also, don't forget that the i5 is probably far more energy efficient than the older Pentium, and so probably wouldn't need as much cooling?
All but the cheapest <$20 aftermarket CPU cooler is better than the one Intel includes with their CPUs. Saving money on CPU cooling is false economy in performance as Intel's coolers are typically just "good enough" for cooling that particular CPU.
Edit: I'm not sure if you're just being thrifty or have very limited cash for proper components, but you often post about 'making do' with old or lower cost components that may be cheaper initially, but are poor choices for price/performance. -
I have always been using an aftermarket CPU cooler and I am just investigating the usability of the Intel ones that I have and I never TRIED.
AnonymousGuest
The higher current fan could be higher rotation speed, but it doesn't have to be.
The Intel ones are almost always less efficient in cooling than after market coolers, So i suggest use after market unless the CPU has a low tdp and will be used in a low end system like a htpc
The copper core Intel coolers are better than the full aluminum ones, but still less efficient than after market ones. -
This is what I am currently using:
https://www.zalman.com/contents/products/view.html?no=347
I did not have any problems with it yet, but it is a little noisy at full speed. -
AnonymousGuestIt has a pwm controlled fan, so you could set in bios the max rotation speed?This is what I am currently using:
The cooler I was using recently failed and I need to replace it with a new one. Do you think the following (that I already have) would do a better job than the Intel cooler?
https://www.zalman.com/US/Product/ProductDetail.do?pageIndex=2&pageSize=10&pageUnit=12...y=&searchWord= -
AnonymousGuest
Mm i doubt that cooler is better than the intel one, both don't have any heatpipes, i think it will make a little difference in favor of zalman
1080p 60fps mp4 capture device...that uses device CPU not PCs CPU?
By Blackout in forum Capturing and VCRReplies: 36Last Post: 11th Sep 2018, 13:40 -
Ex Intel president starting cpu company
By sophisticles in forum ComputerReplies: 1Last Post: 7th Feb 2018, 05:47 -
Intel to make cpu with AMD iGPU!
By sophisticles in forum ComputerReplies: 3Last Post: 6th Nov 2017, 14:26 -
severals hours of rendering can damage an intel cpu with bundle little fan?
By rama in forum ComputerReplies: 16Last Post: 14th May 2017, 13:51 -
What future Intel cpu's will look like
By deadrats in forum ComputerReplies: 4Last Post: 23rd Jun 2014, 15:59
