Hi there
I hope all is well. Could someone please help me diagnose this clip:
https://drive.google.com/open?id=1A6RMJMDnYo7-FGnGFdNh1iMbWy0MHhhM
It's from an NTSC DVD. What would be the way forward to get it to progressive scan?
Results 1 to 25 of 25
Something like this will give 25 fps. Use DGindex to create the d2v file. Instead of yadif you can use qtgmc,
a little better quality, but much slower.
How do you know the output should be 25 fps and not double that of NTSC i.e. 59.94 fps? What settings would you recommend for qtgmc after evaluating that source?
Thank you so much! -
Not to put too fine a point on it, but only by using AviSynth can you undo that mess. If you don't know of it and aren't willing to learn at least a little bit to do the work needed for this video, then there's no other way to fix it. Get and read the docs included in the DGMPGDec package to help you get started.
Also, that DVD is crap and should have been encoded as 16:9 and never field-blended to begin with.
It's typical PAL to NTSC garbage. It's easy to spot because it's pretty common. Just put on a bobber and note all the blending.How do you know the output should be 25 fps...
Films aren't 60fps. They're 24fps. I'd go farther with your source and slow the video to 23.976fps and the audio to match....and not double that of NTSC i.e. 59.94 fps?
The default QTGMC() is fine.What settings would you recommend for qtgmc after evaluating that source? -
My point was that not only are they enough, but it's the only way to properly remove the blending, or most of it anyway.
I don't use AviSynth+ so I can't help there. Both SRestore and QTGMC are third party filters and have to be either placed in the AviSynth Plugins folder or loaded explicitly in your script with the LoadPlugin filter.Okay I tried loading srestore(), it says Avisynth open failure
QTGMC can be difficult to get running as it's particular about the other filters needed to make it work.Last edited by manono; 13th May 2019 at 17:28.
Is it better to use the normal AviSynth and not the plus version?
Would it not be better to specify the frame rate in the srestore function like this:
mpeg2source("C:\VTS_01_03.d2v")
yadif(mode=1,order=1)
Srestore(frate=23.976)
What's the difference between doing that and using the AssumeFPS function? -
Oh okay I understand, thanks for all the assistance it's all good now!
Hey how would you do the audio? I tried saving the video assuming a lower frame rate and it crashed, it displayed some division by zero error. I have a feeling that it's not processing the audio or something. Thanks!
Although it can be done in the script, I prefer to handle the audio separately as I work on it anyway.
BeSweet, among others (eac3to, for example) has a preset to change from 25fps to 23.976fps. Also, any audio editor (such as the freeware Audacity) can slow the audio by a percentage.
If you're doing it within the script, you'd best show the complete script that crashed. -
I kept my old 32 bit AviSynth (MT) installation intact, then installed only the 64 bit version of AviSynth+. That way I have access to both on the same computer. Eventually I found 64 bit versions of most of the filters I use so now I use 64 bit AviSynth+ most of the time.
or Vapoursynth 64bit
, using audio separately with current Avisynth or eac3to and also using QTGMC
but of course new things to learn but just saying , its out there ... -
I don't mind the learning curve. I learn something from each little project
What is the most efficient way to load an image sequence into AviSynth and specifying the frame rate accurately i.e. 24000/1001?
Might be a dumb question: Is it possible to load one image sequence at a certain frame rate and then a second one at a different frame rate into the same video? Let's say you wanted to fast forward or slow down certain sections without using motion interpolation?
Thanks -
To append a series of images with names in the form parta00000.ph, parta00001.png, parta00002.png... and partb00000.png, partb00001.png, partb00002.png...
parta is loaded and its frame rate set to 23.976 fps. partb is loaded and it's frame rate set to 47.952 fps. partb is then slowed to 23.976 fps by duplicating each of its frames. Finally the two clips are joined together into a single clip at 23.976 fps. The frame rates must match for them to be joined into a single clip.Code:parta = ImageSource("parta%05d.png").AssumeFPS(24000, 1001) partb = ImageSource("partb%05d.png").AssmeFPS(48000,1001).ChangeFPS(24000,1001) parta+partb
http://avisynth.nl/index.php/ImageSource
http://avisynth.nl/index.php/FPS -
Most filters in AviSynth take an input and an output. When you don't specify them by name the name "last" is used. At the end of the script last is returned. In my script:
is equivalent to:Code:parta+partb
Your script would fail because there is no "last" to return. You would have to add return(c).Code:last = parta+partb return(last)
NTSC blended from a PAL source, can't restore it properly
By bruno321 in forum RestorationReplies: 5Last Post: 6th Oct 2018, 11:42 -
Need help with AVISynth script - source badly converted from NTSC?
By duffbeer in forum DVD RippingReplies: 3Last Post: 29th Dec 2017, 03:56 -
DVD: have both NTSC & PAL - best source and settings?
By U2Joshua in forum Video ConversionReplies: 4Last Post: 10th Jan 2017, 00:28 -
Laserdisc BEST source (PAL vs NTSC)
By darkbluesky in forum Capturing and VCRReplies: 35Last Post: 8th Jan 2017, 22:28 -
NTSC Pulldown (25p/25i source) on Avisynth
By dpereira141 in forum DVD RippingReplies: 3Last Post: 31st Mar 2015, 18:06
