Hi Guys,
I have been trying to find the info I require but apologies if this has already been answered/
So I download a video from youtube usually the 1080p version. I then render a logo on which takes around 4/5 hours. I then add the subtitles on.
Which programme would be the best to use, which would render the quickest and keep its HD quality.
Current I am using adobe pro because of the length of time it has taken, I swtiched to Format Factory, this was much quicker however I realised quality was being compromised.
Does any one have any tips or recommendations on which programmes I could possible use to shorten the time and keep the quality?
Many thanks in advance.
	What output format is allowed? Some encoders/codecs are better then others. E.g. for a low bitrate target x265 is very good. Many different softwares offer x265 encoding.
 Then of course we don't want to encode too often because every cycle takes time and with a lossy codec also quality. So if possible you should replace "render a logo" and "add the subtitle" by a single step. What kind of logo is that? What kind of subtitle?
	The output file is a .mp4 usually. So it can be uploaded to vimeo / facebook.
 Just a normal .jpeg logo.
 Subtitles are .srt file.
 Many thanks
	You're adding your logo to something you stole from somewhere else? By doing that it then makes it "your" video? And you're burning in subtitles why? The other sites don't allow for external subtitles the way YouTube does?
  Converting 2D PGS subtitles to 3D HalfSBS PGS subtitlesBy RajaSteve in forum SubtitleReplies: 66Last Post: 15th Nov 2019, 09:13
  problem "burning in" subtitles on download video that has soft subtitlesBy kasfig in forum SubtitleReplies: 2Last Post: 1st Feb 2017, 17:47
  Subtitles in a black box to cover up existing embedded subtitles.By Leg_end in forum SubtitleReplies: 4Last Post: 7th Dec 2016, 01:23
  When subtitles aren't subtitles....By jkennedy_4 in forum SubtitleReplies: 6Last Post: 15th Apr 2016, 17:56
  Converting HD-DVD subtitles To BLURAY subtitlesBy wulf109 in forum Blu-ray RippingReplies: 1Last Post: 7th Sep 2014, 07:15
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
