Hello there,
I have a very simple Question.
As ist seems I canīt change the Region codes for Blu-Rays anymore. I already had this Problem and I remeber that I had to empty the Cache somehow but I canīt remember how to this.
I thought it was hitting "stop" multiple times, but it doesnīt work.
Maybe someone here had the same issue and can help me..
was your player region free before ??
have you recently updated the players firmware ?? -
Yes, it was region free before. Just had to change the code on the remote.
No update . -
is the remote working ok, did you try putting fresh batteries in the remote ??
try these codes and see if they work for your player - https://www.videohelp.com/dvdhacks/samsung-bd-f5100/12148
and - https://www.videohelp.com/dvdhacks/samsung-bd-d5100/11534Last edited by october262; 13th May 2019 at 12:26.
Samsung BD-P1600 - Region Free Unlock code
By kennyt in forum Blu-ray RippingReplies: 43Last Post: 17th Apr 2024, 18:54 -
Samsung BD-J7500/XU Region Free Code
By HRAsp in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Mar 2018, 01:02 -
Samsung BD-J5100
By jt_usf in forum DVD & Blu-ray PlayersReplies: 3Last Post: 22nd Dec 2016, 10:41 -
Region code needed for Samsung
By martinalison in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Oct 2016, 20:35 -
Change (not remove) Region code in ISO
By ckeays in forum DVD RippingReplies: 13Last Post: 10th May 2016, 08:23
