Hello,
I am trying to get smdegrain to work on my script, but I'm getting the following error:
Code:mt_lut does not have a named argument "use_expr".
For MCTemporalDenoise I am getting the following error:
Now, I have the latest version of mvtools (2.7.41), so I can't understand what the story is here.Code:there is no function named "MSuper".
Results 1 to 16 of 16
MSuper -> are you sure the mvtools2.dll is loaded?
mt_lut -> are you sure the masktools2.dll is loaded?
without details, my guess it your script doesn't load them and they are not in the avisynth plugin autoload folder,....users currently on my ignore list: deadrats, Stears555, marcorocchini -
Yes, they are both in my plugins folder. I use other scripts/functions whose DLLs or AVSIs are in that folder just fine.
I found the masktools2 (latest release - 2.2.18) but I can't find the dll and there are many folders in the zip. What should I do with this?
Got it for smdegrain. Thanks.
But for McTemporalDenoise, I'm getting the following now:
I'll see what I can find.Code:Removegrain: Invalid mode 20.
RemoveGrain/RGTools has been updated over the years with more modes. You need a newer version. You can probably get rid of the old RemoveGrain and just use the newer RGTools.
Jagabo, do you happen to have a link to the DLL? When I google it, it leads me to the Avisynth docs which leads me to this website
https://github.com/pinterf/RgTools/releases
But their folders NEVER have the actual DLL. What gives? -
The download 7z file contains x86 and x64 folders. The respective dll's are right there.
https://github.com/pinterf/RgTools/releases/download/0.97/RgTools-0.97.7z -
Ok, now I just realized that with 7z files, you have to right-click and select "extract files here", and then you see the x86 and x64 folders.
Thanks. -
What Masktools Version should I use for SMDegrain Mod 3.1.2d?
By VideoFanatic in forum Video ConversionReplies: 4Last Post: 30th Mar 2018, 21:37 -
[AVISynth] Error with MCTemporalDenoise
By sirmechanoid in forum RestorationReplies: 6Last Post: 4th Feb 2018, 20:50 -
MCTemporalDenoise (Avisynth+ MT help)
By frank_zappa in forum RestorationReplies: 0Last Post: 31st Oct 2017, 10:21 -
Record in SD or SD 1080i Upscaled? | Weird Problem with McTemporalDenoise
By MrBiggles in forum RestorationReplies: 13Last Post: 10th Jun 2015, 01:52 -
mctemporaldenoise is altering the colors?
By killerteengohan in forum RestorationReplies: 0Last Post: 22nd May 2015, 19:48
