Hi all,
I have a BM Ultrastudio Pro USB3 device. I'm looking to capture SDI video into the XDCAM EX format. All the software I can find that works with the BM device only does Uncompressed or MJPEG or DVCPROHD.
I am trying to archive a tape library for broadcast and the format we use use is XDCAM EX.
The software would ideally have RS422 time code support. Does anyone know if such a piece of software exists? Preferably free!
Results 1 to 13 of 13
I've tried Sony Vegas...only option other than uncompressed is XDCAM HD422(50mbps). It's a bit overkill for what I'm looking to do. Unless I'm missing something? Was hoping to keep it to XDCAM EX 35mbps. Also couldn't get deck control+timecode to work with Vegas for some reason.
Premiere only showed uncompressed, quicktime uncompressed and MJPEG.
Blackmagic Media Express had the same options as premiere.
I was able to find this software...https://www.magicsoft.tv/recorder.html however you need to purchase a license and get mailed a dongle. I tried the trial and it seemed to have a lot of codec options and worked ok however deck control and timecode also didn't seem to work in it. It looks like it used ffmpeg as the encoder.
Was hoping there would be some type of freeware software that used ffmpeg as the encoder with lots of codec options and also had RS422 support. -
So this is the ffmpeg command I use if I want to convert a file to XDCAM EX
ffmpeg -i "input.mp4" -pix_fmt yuv420p -vcodec mpeg2video -flags +ildct+ilme -top 1 -dc 10 -qmin 1 -lmin "1*QP2LAMBDA" -vtag xdv3 -b:v 35000k -minrate 20000k -maxrate 35000k -bufsize 36408333 -g 15 -bf 2 -aspect 16:9 -r 30000/1001 -async 2 -acodec pcm_s16le -ar 48000 -filter_complex "[0:a]channelsplit[l][r]" -map 0:v -map "[l]" -map "[r]" -f mxf -y "output.MXF" -
How do you start from a mp4 file? I though you are capturing lossless.
Well the idea is that it's an on the fly encode while capturing. I do not want to be separately converting each captured tape. I've got over 1000 of them!
That's the command line I use if I need to convert any type of video file to XDCAM EX -
If you can get that far with Vegas -- use it. Neither Premiere nor Avid will do a direct XDCam capture (except from already encoded XDCam sources.) 50mbps is standard for 1920x1080 material. You can use 35mbps for 1440x1080 or 1280x720 -- but be aware the 1440 will be squeezed.
RS422 deck control requires proper hardware, which your ultrastudio does not have (if I'm looking at the right model.) -
So I was able to capture video from the SDI output using this ffmpeg cmd line
Now I couldn't get any audio yet and I was getting frame drops. I guessing that has to do with buffer settings.ffmpeg -y -f dshow -video_size 1920x1080 -pixel_format uyvy422 -rtbufsize 702000 -framerate 29.97 -i video="Decklink Video Capture" -pix_fmt yuv420p -vcodec mpeg2video -flags +ildct+ilme -top 1 -dc 10 -qmin 1 -lmin "1*QP2LAMBDA" -vtag xdv3 -b:v 35000k -minrate 20000k -maxrate 35000k -bufsize 36408333 -g 15 -bf 2 -aspect 16:9 -r 30000/1001 -f mxf -y "output.MXF"
I would like to record 4 channels of audio from the SDI stream as well as time code information over the RS422 control. Is this even possible? -
I'm getting closer! Was able to get ffmpeg to record video and audio in XDCAM EX, 2ch for now, hoping for 4. However the audio sync seems to be out slightly. Wondering if that'll be fixed by using the ffmpeg build with decklink support. And then I'm still trying to figure out if it's possible to get time code from the RS422 controller.
Here is the cmd line I'm using
ffmpeg -y -threads 8 -f dshow -video_size 1920x1080 -pixel_format uyvy422 -rtbufsize 702000k -framerate 29.97 -i video="Decklink Video Capture":audio="Decklink Audio Capture" -pix_fmt yuv420p -vcodec mpeg2video -flags +ildct+ilme -top 1 -dc 10 -qmin 1 -lmin "1*QP2LAMBDA" -vtag xdv3 -b:v 35000k -minrate 20000k -maxrate 35000k -bufsize 36408333 -g 15 -bf 2 -aspect 16:9 -r 30000/1001 -acodec pcm_s16le -ar 48000 -filter_complex "[0:a]channelsplit[l][r]" -map 0:v -map "[l]" -map "[r]" -f mxf -y "output.MXF" -
So I've got a build of ffmpeg with the decklink feature enabled.
I run this command line to start a capture and transcode to XDCAM EX
It creates a fully usable file however the audio and video is out of sync. The audio is ahead by about 10-15 frames. Here is the ffmpeg output. Any ideas?Code:ffmpeg -y -format_code Hi59 -draw_bars false -f decklink -i "UltraStudio Pro" -pix_fmt yuv420p -vcodec mpeg2video -flags +ildct+ilme -top 1 -dc 10 -qmin 1 -lmin "1*QP2LAMBDA" -vtag xdv3 -b:v 35000k -minrate 35000k -maxrate 35000k -bufsize 36408333 -g 15 -bf 2 -acodec pcm_s16le -ar 48000 -filter_complex "[0:a]channelsplit[l][r]" -map 0:v -map "[l]" -map "[r]" -f mxf -y "output.MXF"
Code:ffmpeg version N-93855-g21832b93d5 Copyright (c) 2000-2019 the FFmpeg developers built with gcc 8.3.0 (Rev2, Built by MSYS2 project) configuration: --disable-autodetect --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --e nable-nvenc --enable-zlib --enable-sdl2 --disable-debug --enable-ffnvcodec --ena ble-nvdec --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvp x --enable-libx264 --enable-libx265 --enable-libdav1d --enable-fontconfig --enab le-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmy sofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enabl e-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwavpack --e nable-libwebp --enable-libxml2 --enable-libzimg --enable-libshine --enable-gpl - -enable-avisynth --enable-libxvid --enable-libaom --enable-libopenmpt --enable-v ersion3 --enable-chromaprint --enable-decklink --enable-frei0r --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libfdk-aac --enable-libflite --enable -libfribidi --enable-libgme --enable-libgsm --enable-libilbc --enable-libkvazaar --enable-libmodplug --enable-libopenh264 --enable-librtmp --enable-librubberban d --enable-libssh --enable-libtesseract --enable-libxavs --enable-libzmq --enabl e-libzvbi --enable-opencl --enable-opengl --enable-libvmaf --enable-libcodec2 -- enable-libsrt --enable-ladspa --enable-openssl --extra-cflags=-fopenmp --extra-l ibs=-lgomp --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++ --extra-cfla gs=-DLIBSSH_STATIC --extra-ldflags='-Wl,--allow-multiple-definition' --extra-cfl ags=-DCACA_STATIC --extra-cflags=-DMODPLUG_STATIC --extra-cflags=-DCHROMAPRINT_N ODLL --extra-libs=-lstdc++ --extra-cflags=-DZMQ_STATIC --extra-libs=-lpsapi --ex tra-cflags=-DLIBXML_STATIC --extra-libs=-liconv --disable-w32threads --extra-cfl ags=-DKVZ_STATIC_LIB --enable-nonfree libavutil 56. 27.100 / 56. 27.100 libavcodec 58. 52.101 / 58. 52.101 libavformat 58. 27.103 / 58. 27.103 libavdevice 58. 7.100 / 58. 7.100 libavfilter 7. 51.100 / 7. 51.100 libswscale 5. 4.101 / 5. 4.101 libswresample 3. 4.100 / 3. 4.100 libpostproc 55. 4.100 / 55. 4.100 [decklink @ 0000000000a8da80] Found Decklink mode 1920 x 1080 with rate 29.97(i) [decklink @ 0000000000a8da80] Frame received (#1) - No input signal detected - F rames dropped 1 Guessed Channel Layout for Input Stream #0.0 : stereo Input #0, decklink, from 'UltraStudio Pro': Duration: N/A, start: 0.000000, bitrate: 995869 kb/s Stream #0:0: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s Stream #0:1: Video: rawvideo (UYVY / 0x59565955), uyvy422(top first), 1920x1 080, 994333 kb/s, 29.97 tbr, 1000k tbn, 1000k tbc Stream mapping: Stream #0:0 (pcm_s16le) -> channelsplit (graph 0) Stream #0:1 -> #0:0 (rawvideo (native) -> mpeg2video (native)) channelsplit:FL (graph 0) -> Stream #0:1 (pcm_s16le) channelsplit:FR (graph 0) -> Stream #0:2 (pcm_s16le) Press [q] to stop, [?] for help [mpeg2video @ 0000000000aab200] Warning vbv_delay will be set to 0xFFFF (=VBR) a s the specified vbv buffer is too large for the given bitrate! [decklink @ 0000000000a8da80] Frame received (#10) - Input returned - Frames dro pped 2 Output #0, mxf, to 'output.MXF': Metadata: encoder : Lavf58.27.103 Stream #0:0: Video: mpeg2video (Main) (xdv3 / 0x33766478), yuv420p(top coded first (swapped)), 1920x1080, q=1-31, 35000 kb/s, 29.97 fps, 29.97 tbn, 29.97 tb c Metadata: encoder : Lavc58.52.101 mpeg2video Side data: cpb: bitrate max/min/avg: 35000000/35000000/35000000 buffer size: 36408333 vbv_delay: -1 Stream #0:1: Audio: pcm_s16le, 48000 Hz, 1 channels (FL), s16, 768 kb/s Metadata: encoder : Lavc58.52.101 pcm_s16le Stream #0:2: Audio: pcm_s16le, 48000 Hz, 1 channels (FR), s16, 768 kb/s Metadata: encoder : Lavc58.52.101 pcm_s16le frame= 16 fps=0.0 q=0.8 size= 85kB time=00:00:00.43 bitrate=1608.1kbits/s frame= 31 fps= 31 q=0.8 size= 2050kB time=00:00:00.93 bitrate=17976.5kbits/ frame= 47 fps= 31 q=1.3 size= 4308kB time=00:00:01.46 bitrate=24036.1kbits/ frame= 62 fps= 30 q=1.3 size= 6715kB time=00:00:01.96 bitrate=27943.5kbits/ frame= 77 fps= 30 q=1.3 size= 8973kB time=00:00:02.46 bitrate=29769.1kbits/ frame= 92 fps= 30 q=1.3 size= 11230kB time=00:00:02.96 bitrate=30978.0kbits/ frame= 108 fps= 30 q=1.3 size= 13638kB time=00:00:03.50 bitrate=31888.0kbits/
Sony j30 SDI no Signal
By ideiasnoescuro in forum Capturing and VCRReplies: 4Last Post: 4th Jan 2019, 05:01 -
FFMBC 0.7.4 now encode XDCAM ok, and FFMPEG?
By marcorocchini in forum Newbie / General discussionsReplies: 7Last Post: 6th Oct 2017, 04:24 -
Canon XF200 SDI out
By Alex1987 in forum Video Streaming DownloadingReplies: 1Last Post: 25th Apr 2016, 14:24 -
SDI Capture Device
By dellsam34 in forum Capturing and VCRReplies: 12Last Post: 19th Mar 2016, 08:28 -
xdcam encoding
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 20th May 2014, 10:45
