Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
  1. I have a .ts file I am trying to convert to Muxed MP2 file. No sync problems playing in Windows Media Player or VLC. I accept AVStoDVD's suggestion to delay audio by -238 ms, but still previews and converts out of sync. I can edit title and uncheck Auto AviSynth Script and change audio delay to 0 and it fixes the out of sync proble when previewed in AVStoDVD, but still is out of sync when converted to Muxed MP2.
    Mar 2008
    Muxed mp2? Do you mean MPG ?
    Try this - use mkvtoolnix to create an MKV from your ts file and use that as input to AVStoDVD.
    If it is still out of sync post the AVStoDVD log
  3. Thank you, I will try that. What is an MPG?
  4. OK, using mkvtoolnix did the trick. Thank you for the tip. What I meant earlier was to use AVStoDVD to convert to a DVD compatible mpeg-2 file for authoring in another program. Sorry for the confusion.
