I just saw a s-vhs vcr that doesn't have any separate s-video jack, but instead only supports s-video quality through scart. Is there any difference in picture quality whether using a s-vhs vcr's scart socket (with a scart s-video adapter) or a s-video jack?
Maybe the question has been asked before, didn't see anyone like this at first glimpse though
Assuming it truly is a s-video signal (luma on one pair, chroma on another separate pair) then I don't see a reason why it would be bad. There may be worse cross talk than with a real s-video cable (just a guess as I don't work with SCART) but having the chroma and luma already separated should be much better than a normal composite signal.
There shouldn't be any difference if you're using proper cables and connectors.
Hmm, just guessing here, but do you, or anyone who works with scart, know if this might have anything to do with the audio and video cables going into the same socket, scart, instead of the cables going to each respective seperate jack into the vcr directly (for example the s-video cable going straight into s-video jack and the audio cables going into each respective seperate audio jacks of the s-vhs vcr)? Does any mix/blending/merging or issue in cross talk occur because of the scart cable? Maybe the 21 pins scart connector doesn't mix/merge or worsen the cross talk between the the audio and video signals to any noticable difference? Just wondering
It might have been vague explained, this is a new territory
SCART S-Video use CVBS for Y signal and C signal is usually routed over Red component signal path (thus condition to keep them separate is fulfilled) but, SCART standard allow to use instead Red component any other remaining component (i.e. Green or Blue). Cheap S-Video SCART adapters may have internally combined Y and C to CVBS (thus they violate S-Video principle to keep separated Y and C signals) .
It can be easily verified even without ohm meter by simply visual inspection how adapter is wired internally. -
I see, I guess I'd go for a slightly little more expensive brand scart cable then like Hama scart to S-video and doesnt support composite (just 13$) https://www.elgiganten.se/product/tv-bild/kablar-och-adapters-tv-bild/HAMA122238/hama-...&gclsrc=aw.ds#
Help with very old VHS tapecapture - difference between two possible VCRs
By ghiga_andrei in forum RestorationReplies: 15Last Post: 28th May 2018, 09:03 -
How to create an mpg, mp3 or mp4 file from VHS? (Using Honestech VHS to DVD
By CambridgeChris in forum Capturing and VCRReplies: 2Last Post: 29th Dec 2016, 09:29 -
Honestech VHS to DVD 2.0 - Software not recording although VHS is playing
By emma1994 in forum Capturing and VCRReplies: 1Last Post: 24th Nov 2016, 17:11 -
I need some help converting my old VHS, VHS-C, and 8mm/Hi8 tapes. Many Q's!
By CZbwoi in forum Capturing and VCRReplies: 80Last Post: 20th Apr 2016, 16:17 -
Capture card for VHS and coaxial (TV) / advice for VHS
By MrPeanut in forum Capturing and VCRReplies: 26Last Post: 24th Feb 2016, 23:06
